Question about Canon MV30i Mini DV Digital Camcorder
Tape won eject - Canon MV30i Mini DV Digital Camcorder
HP SureStor DAT24 won't exit clean mode, won't accept tapes
give it cleaning tape >>> once it finishs cleaning it will eject cleaning tape then you will be able to put any other taps
Apr 08, 2013 | HP Surestore DAT24 DAT Tape Drive
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
Radio won't eject tape
tape is probably caught in the reels, you might have to force it out of the deck, i forced mine out with my eyebrow tweezers, the tape was obviously ruined cause it ripped, but better the tape than the deck...
Aug 17, 2012 | 1997 Buick LeSabre
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
VHS tape won't eject
Hello
Check for any borken drive belt in the mechanism.
Feb 13, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon MV30i Mini DV Digital Camcorder Logo
12 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
