Question about Tablets & eReaders
How to factory reset Proscan 9045k - Tablets & eReaders
What can I d to factory reset my pros can plt7777G tablet.
Hi Patricia,
You can perform a reset / hard reset to completely wipe out the Android phone this will also remove any passwords and configurations.
Note : To perform this process on your own risk
Step by step guide to reset proscan Android Tablet PLT7777G-Q
Step 1: First, turn off the tablet.
Step 2: Press and hold the power button and quickly poke the reset hole until you see an Android logo on screen.
Step 3: Use the paper clip to poke the hole to navigate until you go in to the Wipe data or Factory reset.
Step 4: Use the power button to select and you should be able to see the screen menu.
Step 5: Select the Delete all user data and restart and it will process it then select restart/reboot after the reset.
Once you have reset the device back to factory settings, all data will be deleted and cannot be recovered.
Or: you can also do this by going into the proscan Android Tablet PLT7777G-Q`s settings>backup and reset and selecting the factory data reset option.
Jan 15, 2015 | Tablets & eReaders
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
