Question about Moultrie D55 Digital Camera
AFTER TURNING ON THE DISPLAY SAYS WAIT STARTING
How do I reset my service engine light on a 2000 mitsubishi galant
  • Turn the ignition key to the "ON" position without starting the engine.
  • 2 Press the button to the left of the display on the instrument panel twice within one second. The oil life status will be displayed on the panel -- this should be past the mileage due for the service interval if the wrench icon is illuminated
  • 3 Turn the ignition key to the "OFF" position within 10 seconds of the status display.
  • 4 Press and hold the button to the left of the display again with one hand while turning the ignition key back to the "ON" position without starting the engine. The oil life status will show once again
  • 5 Continue to hold down the button for a few seconds longer, and then release it. Wait 10 seconds until a chime indicates and displays 6,000 miles for at least another 10 seconds.
  • Aug 16, 2016 | Mitsubishi Cars & Trucks
    When starting car, it turns once, stops turning, then keeps turning and usually starts. On occasion, the power windows stop going up. wait a couple of seconds and it goes up a little more. Usually...
    well you should inspect the charging and starting systems although the windows are not part of the starting issue... two different problems
    Dec 30, 2013 | 2002 Buick Century
    Problem with Starting, Samsung SCX-4521F. always show in display ,Warmingup please wait, printer triying to starting, main moter working, but faild,.
    There is a problem with the cardrige.
    1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
    2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
    3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
    4. Press ENTER. The operator panel will display [YES].
    5. Press ENTER. The toner warning message should be gone.
    6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
    If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
    Apr 16, 2011 | Samsung Office Equipment & Supplies
    Have 1-min on the digital display. wait 15
    It sounds like you have a restriction going to the pump.You have a filter which needs to be cleaned.
    Nov 10, 2009 | Whirlpool GHW9100L Front Load Washer
    1999 Pontiac Sunfire ignition lock cylinder changed but car has anti theft and car wont start. How can I get it to start?
    try turning the ignition on try to start then without shutting key off wait 10 mins then shut key off then back on but do not try starting leave on for ten mins then back off turn key back on to run but do not try starting it wait ten mins then if it reset it should crank over and start if not repeat all steps again
    Sep 19, 2009 | 1999 Pontiac Sunfire
    Help with Pioneer Elite Pro-1130HD 50 inch
    just wait it, because it is processing the display data
    Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
    PLASMA DISPLAY STARTING UP. PLEASE WAIT
    Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
    Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
    Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
    Please wait is all the display says
    Replace Your Hard Drive. It will fix your problem.
    Nov 20, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
    Moultrie D55 Digital Camera Logo
    70 people viewed this question
    Top Moultrie Cameras Experts
    Steve
    AZBen
    AZBen
    Are you a Moultrie Camera Expert? Answer questions, earn points and help others
