Question about Harley Davidson 426290 AM/FM Radio
Battery eprom Where are the batteries located?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
There are no batteries
Posted on Dec 29, 2013
I am locked out of my bios
without knowing which scanner you talking about, i am assuming you have forgot the system password for the EPROM/;BIOS. Same procedure as motherboard, remove AC power, locate CMOS battery - likely a round lithium tablet, remove for 1 minute, replace, plug AC power back in. should be reset.
Jun 13, 2011 | Computers & Internet
I'm having trouble removing a bios password from my latitude d631. I tried removing the battery for a few hours, and dozens of default master passwords. Nothing's worked and this is alot of trouble just to...
there are a few options, if there is no small battery on the motherboard you can either replace the eprom chip or do a paperclip trick. on ebay there are password removal sellers for around $20
sometimes they can help , but it sounds like its locked in you eprom the paperclip trick involves removing the motherboard and powering on the laptop while jumping the pins on the eprom chip with a paperclip.
Feb 07, 2011 | Dell Computers & Internet
Morning can you please assist me on my Dell latitude D620 to locate which one is the Bios Chip and the EPROM for the bios. I need to remove the bios password
A faulty alternator in the engine of the car can also reduce the life of a battery. If it does not produce enough charge to supply enough Dell Inspiron 1501 Battery, the weight will gradually uncharged sulfate, which means that the capacity over time the battery will be less and less until it is practically useless . The batteries that are smaller will prove cold weather, a battery uses more charge to deliver a cold engine and if it does not have enough power, the engine will not start.
Nov 15, 2010 | Computers & Internet
Power-On Password reset and SVP
The supervisor (SVP) password is stored in a chip called 24RF08.It can not be reset by disconnecting the BIOS battery or shorting any jumper.
Nov 24, 2009 | IBM ThinkPad T43 Notebook
We bought a magnavox tv from a hotel and some channels are blocked and we can't get all of our cable channels. Is there a way to reprogram the tv? It is a 25' and it's about 10 years old and in good shape....
the eprom that holds the stored codes needs to be wiped clean or re-set...unfortunately, unless the original remote is available to get into the menu...it will have to be done manually by a technician. the set needs to be opened, the eprom located, the proper pin-outs located and then proceed with resetting. if the eprom is an older type, then the codes were usually held there by a back up battery or super cap...in which case, you just need to remove the battery or super cap for a couple minutes.
silvio
Jun 30, 2009 | Philips Magnavox 27MS343S 27" TV
I have a small Orion TV, model TV 1334A. Everytime I move the darn thing I have to set it up again! Hope you have directions I can print out, this drives me nuts!!! I can't afford another TV right now....
I have not worked on your model. I will answer genericaly:
If you are not used to doing TV service you will have to give the set to a TV service center to fix this.
On many of these types of sets on the main board or a daughter board there is a silver oxide battery that is like a calculator battery.
If you are able to work on the set, open it up and look for this battery. If there is a battery in your set, take note of the number on it. You can get one and then replace it.
If your set is a model that does not use a battery, there are two other ways memory is held. Some models use a gold leaf capacitor. It will take TV service experience to be able to locate and change this capacitor. This type of cap would be a special order from a parts supplier.
The other method is they store the setup in an EPROM. In this case the EPROM or the uPC can have a fault. In this case servicing the set would be not feasible.
Jerry G.
Feb 22, 2009 | Orion Televison & Video
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
PTC-701 Memory
http://www.barcodetrader.com/telxon-ptc-610.html
They seem to deal alot of these, maybe they have what you need.
Jan 12, 2009 | Symbol PTC 701 Portable Terminal
I have ibm t23 or 2647
Try removing the backup battery for the bios and the main battery. The bios battery is a small little lithium battery usually located under the memory access panel. Killing the bios backup power causes it to lose its memory and go back to default, AKA No More Password. If this does not work you must find the security eeprom located somewhere on the motherboard and short pin 3 to pin 6 with a paper clip and power up. This will set the security eeprom back to manufacturing mode and once again, no more password.
In the most extreme cases the eeprom actually has to be replaced, this only occurs on very high end units. If you have any questions feel free to contact me. Good luck.
George
Ps. you can find the location of the eeprom easy just google for your model laptops security eprom.
Jul 16, 2008 | Acer Aspire 5100 Notebook
DS will not keep settings
the main battery is the only battery that keeps the DS memory there is no internal clock battery or anything so it will most likley be your main battery that is dead.
Quick point though, if this is the case your DS should not boot. if it does boot and the settings are lost then I would check the battery terminals to make sure they are connecting okay.
Other than this it could be an eprom on the main board at fault maybe.
Good luck
May 16, 2008 | Nintendo DS Console
Harley Davidson 426290 AM/FM Radio Logo
107 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
