Question about Nebo SE Redline 250 Lumen L.E.D Flashlight 5615
Redline 250 flashlight is dim
The light is quite dull even on the high setting. I have put new batteries in several times with no change in output.
2013 ford explorer has dim yellow headlights even on high beam, alternator seems ok
That would be a failing battery, dead cell, or bad grounds on both lighting circuits. Have the battery stress tested in a garage. The test takes 30 seconds and is free.
The alternator just charges the battery.
Feb 07, 2017 | 2013 Ford - Explorer
Highbeam lights very dull on 1999 Geo prism? Put new wiring plug(?) Any idea what the problem is? on and change dimmer relay with no luck! Ant
are you in USA.?
are you in Canada with mandatory DRL lighting?
we can not guess that,
DRL car is complex.
DRL has a 20 pin module just for DRL, crazy complex.
the FLASH on DRL grounds the HL directly bypassing DRL relay
so is super important the FLASH test.
There are 2 systems used, the toyota uses hot all time headlights
(via the HL relay and dimmer relay)
I need this?
is it dim on high, yes,
is it dim on low, no.
is it dim , when you push the lever to FLASH.??????
if flash works we know why it fails. see? (paths)
see?
if high beams and FLASH are dim, then DRL relay bad.
(can be other failures., for sure even wires bad)
its just a:
Toyota Corolla. Gen 6 to 8. (in snake skins)
if you have voltmeter this is child's play , really
finding point of voltage drop tells you what is wrong
find a shop with sparks guy? be best or by a meter and learn>?
guessing can take a long long weekend.
is labor time not a matter to you or down time?
ok I pulled up your cars HL schematic.
DRL is super complex
id pull the DRL module and look for burned pins
they love to do that DRL does.
so got DRL
and does FLASH work right>?
Jan 21, 2017 | Geo Cars & Trucks
How to charge Coast PX45?
not a rechargable light .put in new batteries
Jul 01, 2016 | Coast PX45 LED Flashlight
Can I buy a battery holder or frame for my NEBO Select flashlight?? My grandson dropped mine in the lake while changing batteries.
Given the cost and availability of those lights vs the expense for the battery carrier, you should just get a new light.
Feb 20, 2016 | Nebo Redline Select 310 Lumen Flashlight...
Need a replacement bulb for a Redline Nebo flashlight
Hi, replacement bulbs can be found at amazon, click here and take a look: Amazon com flashlight replacement bulb. Cheers
Nov 02, 2012 | Nebo Redline Tactical Flashlight Strobe...
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
Charging system not charging like it should.
check the generator output as this normaly fails on this model
Mar 08, 2009 | 1993 Yamaha FZ 750 KT (Europe)
Bad battery ???
It sounds like the battery has just enough "juice" to give the small light some power, but when the larger light is turned on it overloads the bad (or expired) battery. When you put a new battery in you can extend the life by not using the light when the battery starts to die. This is when it starts to permanently damage the battery. Turn it off and recharge as soon as it dims. Charge often, but don't leave on the charger too long unless it is a smart charger and turns off when the battery is fully charged. This will also reduce the life. You can find a replacement battery here: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jan 16, 2009 | Camping, Backpacking & Hiking
Head Lights
If only the headlights are dull and not putting out the correct light, I would suspect a bad ground (earth) connection somewhere in the headlight circuit or the fuse for the headlight circuit. Something is causing excessive resistance and causing less voltage to be provided for the headlights. If all the lights are dimly lit, then I would check the charging system, the battery and the ground cable for the battery, chassis, and engine.
Jun 13, 2008 | 1995 Ford Crown Victoria
Nebo SE Redline 250 Lumen L.E.D Flashlight 5615 Logo
42 people viewed this question
Top Nebo Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Nebo Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
