Question about Electro Brand Nostalgic Stereo CD Music System Shelf System
Wont power on
We plugged it in and turned to CD and it openened and we played CD, but the seconda time would not work on CD, radio or tape
2003 monte carlo, radio plays, but none of the buttons work, no display
All you can do is remove the radio and have it repaired by a local approved GM radio repair shop.
Jul 11, 2017 | 2003 Chevrolet Monte Carlo
I have an rca portable radio tape and cd player RCD175, and it plays good, but wont play cassette tapes. I put the tape in and press pas and the play button wont stay pressed in. What causes that?
Hello
It is due the mechanism trouble to your set. The casette tape deck mechanism should be troubleshooted. It is a skilled work. Just contact any experienced service technician to make this set right.
Feb 28, 2012 | Audio Players & Recorders
THE CD PLAYER PLAY ONLY FOR HALF HOUR THEN JUST CUT OUT, LIKE A ELCTRIC ERROR SOUND, NO SOUND, BUT THE RADIO AND TAPE PLAY WITH SOUND. CAN YOU HELP PLEASE MARIANA
CD PLAYER OVERHEATING -- NOT MOUNTED RIGHT .. I HAVE SEEN THIS PROBLEM MANY TIMES AND WORSE IN SUMMER OR WHEN THE CAR HEATER TURNED ON THAT SENDS HEAT FROM UNDER THE DASHBOARD TO THE CD PLAYER ......
HAVE SOMEONE TAKE THE UNIT OUT OF THE CAR AND POWER IT UP ON A WORK BENCH. IF IT CAN PLAY FOR HOURS THEN THIS IS THE PROBLEM. IF IT ALSO STOPS PLAYING WHEN OUT OF THE CAR THEN THE LASER NEEDS CHANGING ......
Jun 20, 2011 | Car Audio & Video
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
Radio 80c7e80b will not play, only get static on AM/FM CD Works
your radio is shot, and the cd and tape player still works. You have to buy a new radio if you want to listen to a radio.
tepfy
Jun 10, 2009 | 2002 Chrysler Town & Country
Panasonic XRB RXCT950 Boom box radio,tape and plug in CD player
It sounds like your unit has a LOT of broken solder connections and dirty potentiometers. Unless you are VERY good at soldering and want to invest about 1 to 2 hours of time, I would toss it and start fresh.
Jun 16, 2008 | Panasonic Audio Players & Recorders
Stereo component
It has a driving motor belts problem so send it to service provider.
Feb 26, 2007 | JVC MX-D302T Shelf System
Electro Brand Nostalgic Stereo CD Music System Shelf System Logo
15 people viewed this question
Top Electro Brand Audio Players & Recorders Experts
Ben Armstrong
Shehu Pro
Shehu Pro
Are you an Electro Brand Audio Player and Recorder Expert? Answer questions, earn points and help others
