Washer is leaving grease all over my clothes
My westinghouse HD 18 constellation washer is leaving grease stains on all my clothes what can cause it
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
Posted on Aug 20, 2010
    Problem Solver:
  • 14 Answers
Time to have your transmission replaced.
Posted on May 18, 2009
Washing machine is making grease spots on clothes
Thank you for your post, friend!
From what you are describing your Frigidaire washer is leaving grease stains on your clothing. I would recommend cleaning your washer with a hot water cycle and bleach. Additionally, it could be a possible issue with your motor, drain pump, or rear bearing and I would suggest seeking assistance from a professional for proper diagnosis and repair. -Matt
Oct 19, 2014 | Frigidaire Washing Machines
Washer leaves oil type stain on clothes.what could be cause?
Stains on clothes from this model of washer are usually caused by the door boot or the tub bearing going out. I recommend cleaning off the surface of the door boot and if you still get stained clothes I recommend having the rear tub & basket checked. I am also sending you more troubleshooting tips in the image below.
Dec 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
What will cause black grease stains on clothes in a GE washer, when the clothes are not greasy going in. Agitator seems a little loose.
It maybe a bit of grease worked it's way down inside the agitator,check if there is a way to "torque" down the device.
Mar 28, 2010 | GE WJSR2070B Top Load Washer
My washer is leaving discolored stains on my clothes. it shows up most prominently on whites, they almost look like shadow stains, but they're getting worse. what is causing this?
If this is a top load machine, you have a bad tub bearing. This will cause your clothes to have what looks like rust stains on them. It's actually grease form the bearing. It can be replaced and I would rate it a 6 on a scale of 1 to 10, 10 being the hardest.
Please rate solution
Sep 02, 2009 | Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothing stains
Get a flash light and look very closely at the entire inside of the washer. what you are looking for is a little yellow grease, which is causing this problem. if you find the grease, remove it with a degreaser and you will be fine.
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
664 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
