Question about Moen S3371 ExactTemp ¾” Thermostatic Rough-In Valve
Installed "upside down"
I have a problem regarding my recent installation of the Exacttemp shower valve: I accidentally installed the valve "upside down", meaning rotated 180 degrees, such that the tub outlet now faces up, and the shower outlet faces down. I capped the down-facing shower outlet and am using the original tub outlet (facing up) only, regulated by three flow valves (to shower, tub, and handheld). My question is: If I adapt the hot and cold water inlets, can I leave the valve in upside down or do I need to redo the install? Thanks for all and any help!
  • 6 Answers
SOURCE: not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Posted on Jan 09, 2009
  • 102 Answers
SOURCE: low water flow in Shower
Definitely try reversing the cartridge.
Posted on Mar 11, 2009
  • 349 Answers
SOURCE: We have a home that
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Posted on Aug 15, 2010
Suzman
  • 642 Answers
SOURCE: Problem: Spout on Moen
The rotating spout is one of the features of the product as listed here. You can download the exploded parts view as well if you're not sure you got the assembly right.
Posted on Oct 17, 2010
  • 7 Answers
SOURCE: Moen Refresh? Shower Head 3-Way
Hi Rebecca,
Sorry to hear that your shower head hose is leaking. If you could please provide a few details to our Consumer Services team, someone can help you reach a solution. You can either visit http://www.moen.com/consumer-support/contact-us or call 1-800-BUY-MOEN.
Thanks
-Olivia from Moen
Posted on Jan 06, 2011
I installed a Tuscany shower valve and the hot and cold are reversed. I didn;t change any of the piping and hope there is a way to adjust with the cartridge. Help!
I am not familiar with that valve, but I hope I can offer some help. It may be that you installed the valve upside down. Every shower valve I have ever installed has writing on the back that says; UP. If you still have access to the rough-in valve, you may want to check that. Also, if it is installed upside down, you can try to pull the cartridge, flip it and reinstall it. That does not work with all cartridges, but it is worth trying if the rough-in is installed upside down.
Oct 17, 2014 | Home
Moen cartridge is 90 degrees off
Cartridge has been installed upside down. Remove, spin 180 degrees and re-install.
May 03, 2014 | Moen & Posi-Temp Single Handle Shower Or...
My Moen exacttemp thermostatic shower goes to either hot or cold - can't figure out how to control the temp. This was just installed and the installer didn't provide instructions.
Your meon shower has a carriage the handle is attached to, sounds like there might be something in it or the carriages is warn and needs replacing.
Apr 17, 2011 | Moen TL3450/3600/3371 Kingsley Handle Tub...
I lost the install instructions for my Moen 270 exact temp shower kit.
Moen Chrome ExactTemp Vertical Spa:
http://www.moen.com/moen/chrome-exacttemp-r-vertical-spa/_/R-CONSUMER%3ATS270
Product Specifications:
http://www.moen.com/shared/pdf/ts270sp.pdf
Exploded Parts View:
http://www.moen.com/shared/pdf/ts270pt.pdf
Replacement Parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=TS270
Unfortunately the installation Instruction Sheets/Owner's Manual are not posted for the 270 models. Suggest you contact Moen Consumer Support directly to make a request:
Apr 02, 2011 | Home
Water came out both shower head and tub spout (even w/o spout)
The shower valve is clearly mark "UP" when you look at it from the front.
Nov 17, 2009 | Plumbing
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Hot and cold oscillations on my deva envy shower
no man i installed plenty of shower valves if your in the shower looking at it the left is hot always just make sure ur holding it right side up most of them have a plug that goes in the bottom to block the tub spout and the top goes to the shower are maby u put it in upside down? good luck man if you run in to another prob, post again good luck
Apr 11, 2009 | Plumbing
Not able to pull up the shower valve
The valve is in upside down. Sounds like the shower head runs all the time and thats what fills the tub? The valve needs to be flipped OR the diverter in the valve needs to be switched to the other side of the valve. If this is a one handled valve it is installed upside down. UP is indicated on the valve.
The valve can be reused just turned over.
Dec 13, 2008 | Moen 2919 Chateau Two Handle Tub and...
Shower/spout
The valve is installed upside down and needs to be reversed. There is a diverter in the valve that gives the spout priority. When the valve is upside down it gives the shower head priority. Thats why it runs without the diverter being activated. You will need to get in the wall from one side or the other. Cut the valve out and either flip the faucet Or change the direction of the diverter depending on the style of valve.
Good Luck, Phil
Dec 10, 2008 | Price Pfister 01-111 Shower Head, Tub...
Moen S3371 ExactTemp ¾” Thermostatic Rough-In Valve Logo
95 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
