Question about Coffee Makers & Espresso Machines
Cuisinart coffee grinder
Just stopped working; nothing turs on, no lights. Initially the program button flashed. Then, that died too.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Time to buy new one
Posted on Dec 28, 2013
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
  • 85 Answers
SOURCE: My Cuisinart 12 cup programmable coffee maker will
Hello jimmarsh,
You are right, there is a way to fix this. This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
SOURCE: I just preapred my Cuisinart to brew coffee. Now,
yes, it is.
Posted on Jan 18, 2010
SOURCE: We have a Cuisinart DGB-900
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Posted on Sep 08, 2010
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Posted on May 27, 2012
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Program light is blinking and will not turn off
Mak sure all pats are back together, grinder unti top to grinder unit, closed basket etc. If the beepin will not stop after that unplug unit for about 5 minutes then plug back in , once again making sure everything is closed. The beeping is to warn you that a part is not there and a leak is posible if tht the case. Hope that helps, Steve
Jul 28, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grind and brew's program light wont stop blinking
Could be electrical, but: Hold in the program set button for several seconds. Set it for some time. Press the program set button one more time. See if it resolves the issue.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart DGB-500 Coffee Maker
Programable Timer
After you follow the directions in the manual, you have to press the Program button one more time so that it lights up - THEN it will make coffee at the set time.
Aug 22, 2008 | Cuisinart Thermal DGB-600 Grinder
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Nov 09, 2007 | Cuisinart Supreme Grind CCM-16PC Grinder
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart grind and brew coffee maker
here is the link to the manual; http://www.cuisinart.com/share/man/34_man.pdf ask again if you still haven't figured it out :)
Mar 15, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
15 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
