Question about Radio Shack Accurian ADR-3223
DISC TRAY DOES NOT OPEN
THE DISC TRAY DOES NOT ALWAYS OPENS
Will only open tray # 4
Check its loading belt. Replace it.
Jun 05, 2012 | Philips MCM530 CD Shelf System
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Tray wont open
Power your unit off using the button. when it's off unplug the power source from the back of the XBOX and leave it out for 30 sec. Reconnect the power source and reboot your machine. Try the disc tray again. If it doesn't work try giving it a tap or a solid knock on the top of the case above the disc tray while it's trying to open. Don't drop the machine or try to pry the tray open. If it doesn't open when you tap it then try light pressure on the front of the tray while it's trying to open. (you can tell it's trying to open because the disc status on the screen will say opening...)
Now if the above did not work
Get a straightened paper clip.
Remove the faceplate carefully starting from the indention that you will see on the side
After removing the faceplate, look for a pinhole just below the disc tray.
*There are two pinholes just below the cover of the disc tray and one pinhole below the X and B of XBOX logo.
*You can try any of the three holes
*Pinholes are so small that the girth of the paper clip is the only object that can fit through the pinhole.
Now insert the paper clip into the pinhole then put a little pressure until the disc opens.
If it opens try to close it, if it closes try opening it again, if it wont open the second time then it need to be serviced
If it opens try to close it, if it wont close try nudging the disc to the right and then to the left, if nudging doesnt then it need service
If it wont open after trying all three pinholes - its needs service
It may be jammed or the drive gear stripped.
CALL XBOX CUSTOMER SUPPORT 1-800-FORMYXBOX
If that doesn't work . call Microsoft and they will instruct you on warranty work.
Nov 24, 2009 | Microsoft Xbox 360 Console
My DVD tray will not open, and with no disc inside the display says 'reading' constantly. Any thoughts?
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. I had to do this on my unit and therefore I recommed leaving a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Oct 11, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
Always opening disc tray
3 things cause this:-
A Damaged Disk, A Dirty Disk, or a Hardware fault.
Below is Microsoft's doc on the issue.
http://support.microsoft.com/?scid=kb;en-gb;816779
If my advice was helpful, please vote for me!
Nov 16, 2007 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Radio Shack Accurian ADR-3223 Logo
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
