What am i suppose to plug the microphone into.
I have the Spectruam AIL-105 but i have know idea what to plug it into the plug will not fit into my laptop anywhere and im not sure if it should be plugged into a computer and if its suppose to be plugged into a speaker i do not have a speaker. Did i waste my money?
  • 165 Answers
Hello chelsea dont panic if you are so shure what you bought is for your laptop just get an adaptor to reduce your plug and the other can plug into the lap yours antonio
Posted on Dec 29, 2013
SOURCE: PROBLEM WITH MICROPHONE
I will Give u a solution but u have to do me something
Posted on May 26, 2008
M2Tech1
  • 313 Answers
SOURCE: the microphone is not detected
you cn check the connection b going into the properties of your sound card page and go to the section for input check if the mic shows up have you any drivers loaded for the mic... if you go to setting then control panel look for the sound and audio box there is block there for speech check you mic is selected.. you can try connecting via afront panel usb port as well or via you sound card inputs on the back panel
Posted on Jul 31, 2009
SOURCE: I have my logitech desktop microphone plugged in but it wont work
go to control panel - speech recognition[sic] and then a sceer comes up where it asks questions 2nd one set-up my mic. It worked for me and i use vista 64(sucky)
Posted on Feb 15, 2010
oldmanewtoys
  • 414 Answers
SOURCE: my microphone is plugged in but it wont let me
You have to have a audio recorder viia your computer software. Try NCH or Audicity both of which are freeware programs
Posted on Feb 26, 2010
moshal85
  • 10 Answers
SOURCE: Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Posted on Apr 29, 2010
I need help to tune my tv please
Global Download Center Visit this site to download the user manual to this set. It has all details.
Apr 16, 2015 | Televison & Video
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
Pre wired switches for 89 etc Harley soft ail
Check with Drag Specialties. I bought new switches from them last year for my '91 Harley.
Aug 15, 2012 | Harley Davidson FXSTS Springer Softail...
Sony Vaio PCG-K33 will not power up
Hi
Ensure battery is secure, If so try removing it and plugging power supply in.ensure all power supply plugs are very tight and fitted, unplug each one and re-plug in to be sure. Sometimes the power supply lamp can be on but not actually supplying power out the other end.
Aug 17, 2009 | Sony VAIO PCG-K33 Notebook
Problem with usb hub port
I am not sure what make of laptop you have but most of them have whats called a pcmcia slot on the dside of the laptop. You can buy very inexpensively, a card that will fit into the pcmcia and will give u anywhere from two to 4 usb ports.
Hope this helps
Mark
Jul 04, 2009 | Dell Latitude D620 Notebook
A-105 S1712 Powerless
yeah,reseating the cmos battery will reset you bios settings to factory default,so whatever memory that is attached to your computer should be detected..
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Unlock parental control
The parental lock is set by the user - possibly the individual who advertised the player for sale.
Oct 21, 2017 | GE Televison & Video
Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Jan 11, 2008 | Canon Sure Shot 105 Zoom 35mm Point and...
Open Questions:
 Grubhead
Grubhead
