Question about i-mate JAM Pocket PC
Screen aligniation My pohone started showing some troubles recognizing taps at the right side of the screen. This happened before but I reset the phone and the problem got fixed. Some times I had to perform a complete reset. Today it happened again but now I'm not able to get out from the aligniation screen. I keep tapping the screen without a possitive response.
  • 1 more comment
  • Anonymous Nov 07, 2007
    my screen does not recognize or sense any tap, left side worked but now it is also not working ...i took out battery and restarted it but it didnt work ....
  • chkaran Nov 12, 2007
    Iam using I-Mate Jam started showing some troubles recognizing taps at the right side of the screen. This happened before but I reset the phone and the problem got fixed. Some times I had to perform a complete reset. but now it repeatly showing tap screen i am unable to get in
    please help me
    karan_maya2007@yahoo.co.in
  • bimbobaby Nov 15, 2007
    my i-mate jam didn't respond to stylus tap.i did a full reset but did not respond to (tap the screen to set up your pocket pc message)
Repalce the screen it is faulty
Posted on Oct 26, 2007
I forgot password and now I cant access my tablet.
Here are some options which came from the trio tablet website: What do do if forgot my password to unlock to my tablet
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
This site also had some tips: Different Hard reset factory wipe methods for Android Tablet
Mar 21, 2016 | Audio Players & Recorders
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
Or
Jan 04, 2016 | Tablets & eReaders
After a power failure we got the error code C0500 when power was switched on again
Enter in the service mode STOP 0 STOP 0 1 ,press trouble reset,or open close the front door.
Jan 28, 2013 | Minolta DI-2010F Copier
Master reset for lg vp200
Lg incite hard resetTo perform a hard reset
• A Hard Reset should only be performed after all other trouble shooting options have been exhausted.
After a hard reset, the device is restored to its default settings - the way it was when you first
purchased it and turned it on. Any programs you installed, data you entered, and settings you
customized on your device will be lost.
1. Power the device ON
2. Tap Start > Settings > System tab > Clear Storage.
3. Enter 1234 for the password twice.
4. Press Enter.
5. Select what to reset.
You have to enter your password and confirm again for hard reset. However when you forget your
password, the only way to hard reset the device is via the hard key sequence.
1. Power the device OFF.
2. Press and hold the following hard keys in sequence.
left side - down rocker button - right side camera button - front right phone button
Keep pressing keys until your LCD screen turns on.
Align screen will appear if you success hard key reset.
Sep 05, 2012 | LG Cell Phones
GPS screen goes black
Try to keep the memory as empty as poss to avoid this in the future. Clear old data on a regular basis that is not longer needed.
Jun 08, 2012 | Garmin Nuvi 760 Car GPS Receiver
Forgot password for router
Hi, Do you have a computer that is connected to the wireless network ?
If yes, Heres how to get the password.
Find your password on a Windows PC
If you have a computer running Windows that is connected to your wireless network, you can find the password by doing the following:
Windows 8.1: Find your password Step 1: Swipe in from the right edge of the screen, and tap Settings.
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click Settings.) Step 2: Tap or click the network icon (d6916536-a5d6-48c3-9da5-a5e1b1911348.png?n=wireless-network-icon.png or a2df8796-16ee-4862-b451-a6300d187118.png?n=network.png%20alt%20text%20=%20wired%20network%20icon) for the network you want to connect to, and then tap or clickConnect. Step 3: Swipe in from the right edge of the screen, and tap or click Search. Step 4: In the search box, enter view network connections, and in the search results tap or click View network connections. Step 5: In the Network Connections window, press and hold or right-click the network name, and then tap or clickStatus. Step 6: Tap or click the Wireless Properties button. Step 7: Tap or click the Security tab, and tap or click the Show characters check box. Step 8: The password for the wireless network is displayed in the Network security key field. Windows 8: Find your password Step 1: From the Start screen, swipe in from the right edge of the screen, and then tap Settings.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Settings.) Step 2: Tap or click the wireless network icon d6916536-a5d6-48c3-9da5-a5e1b1911348.png?n=wireless-network-icon.png. Step 3: Tap and hold or right click on a wireless network name, and then choose View connection properties. Step 4: Select Show characters to see the wireless network password. Windows 7: Find your password
Step 1: Click the wireless network icon on the taskbar (lower-right corner). Step 2: Right-click your wireless network name, and then select Properties. Step 3: Select Show characters to see the wireless network password.
Hope this helps
Regards
Rakesh Warrier
facebook.com/quietmouse89
Jan 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I unlock my lg insite from att
4. Press Enter.
Nov 01, 2009 | AT&T Cell Phones
My Tom Tom 530 switches on ok but screen shows no signal, when outside. I have pressed the reset button problem still persists. Can you help! Thanks.
Tap the map screen in the lower right hand side where the bars are then tap the screen on the upper right hand side where the battery is. This will bring you to the satellite screen. Leave it alone for about a minute if you don't see any grey bars showing on the bottom of the screen your unit has a problem. If you do see grey bars at the bottom leave it alone and let it do it's thing. Sometimes for the first time after not using it for awhile it may take up to a 1/2 hour for it to locate the satellite's
May 08, 2009 | GPS
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
i-mate JAM Pocket PC Logo
Top i-mate Computers & Internet Experts
iphone service
Oloyede Monsuru
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
