Question about Whirlpool 24 in. GU980SCG Built-in Dishwasher
DISHWASHER IS RUNNING BUT NOT FILLING UP WITH WATER
  • 234 Answers
Your problem is probably the water fill valve is defective or it may be the drain valve is stuck open. If it is not filling with water at all, it is probably the fill valve. If it is filling as fast as it is draining, it is probably the drain valve.
If you need more help, post another comment.
Thanks,
Tim
Posted on Jun 16, 2009
  • Tim Phipps Jun 16, 2009
    It is also possible that the float switch is defective and it is telling the machine that it is full of water.
  • chris_55904 Feb 07, 2011
    The float switch turns the water off when it senses a high level, I have been looking at mine and just tried it. I have the same problem as the person above and have 6.8 ohms at the coil so it is good. Sounds like the drain valve is open for some reason.
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My dishwasher is running but not filling? Water is on & connected but can't work out why it won't fill. Any solutions? Thanks
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 13, 2011 | Ariston Technologies L63SNA Stainless...
The washer is not getting any water. It is running dry.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Kenmore Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Water is not filling into dishwasher. Everything sounds like it is running ok and water supply is on.
Go to the back of the machine, where the main water inlet connects. The connection there is the inlet valve that should open when you switch the machine on. Usually you have to remove the machine outer casing to get to the valve. The valves are quite cheap. Cheers, Derek.
May 19, 2009 | Dishwashers
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
MayTag Dishwasher Quiet Series 300
If it is not filling enough, you may need a new water valve. It may be plugged.
Nov 19, 2007 | Dishwashers
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
187 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
