Question about 2007 Chevy Impala ABS Plastic Rear Lip Air Dam 179-200-2 Razzi
No power to fuel pump
Well I put a brand new fuel pump in and im not getting any power to the fuel pump what the heck is wrong the fuses are good and the relays are all good what els could it be
  • 69 Answers
You need to check that you are getting voltage to the connection going into the fuel pump receptacle. If you are then my bet is you got a faulty fuel pump. If you don't get voltage then you need to troubleshoot why the voltage is not getting to the fuel pump. Hope it helps and good luck...
Posted on Dec 29, 2013
New fuel pump still wont start
check the pressure sensor in the fuel manifold as it directs power to the CPU to turn on the fuel pump
Apr 06, 2014 | 2001 BMW 325i
What can I do to figure out why my van does not keep the battery charged I changed all the fuses and still not charging
you have a short somewhere im your wireing i would start with any groung that you may have made when u did your rigging and then go through all your wires and make sure none of them are wore down and touching any metal
Jan 22, 2013 | 2004 Ford E250
Isnt getting any power to the fuel pump
Should be a designated fuse for the power to the fuel pump I'm not familuar with this model but some vehicals with electric fuel pumps have a reset swich on the pump or under the hood on the fire wall.
Aug 22, 2012 | 1987 Toyota Supra
Im not getting any power to the fuel pump
In the fuse box is a fuel pump relay, most relays are the same switch them around.
Put in new fuel pump,fuses are OK,new fuel pump relay and still no power to the fuel pump
Get a test light and test the wires going to it ground one end and see if you have power at the pump. If not do the same at the fuses so where you are not geting the power.
Aug 19, 2012 | 1998 Pontiac Grand Prix
OK i have a 1999 gmc Yukon i just changed the fuel pump spark plugs ing coil control module wires but she still wont crank she starts then shuts off whats wrong HEPL ME PLZ
I suppose that you mean it starts but doesn't continue to run. And if you try to start it right away it'll just crank. The fuel pump is on in crank but not in run ( maybe ). Find the fuel pump relay in the underhood fuse relay panel and use a test light to cheak the pins for power and ground. First with the test light hooked to a good ground, check to see if it works first ( touch the battery positive ) then touch all the pins of the relay ( removed ) One should be hot all the time ( if not the fuel pump fuse is blown) another should be hot with the key on. one of the others will be hot only in crank ( this is the fuel pump) The last other is ground with the engine running after started. The one thats hot in crank put power to it with a jumper wire and start the engine ( it'll run ) the fuel pump also gets turned on by the oil pressure switch and the fuel pump fuse is blown it'll also not run the engine. But it'll run right after it's cranked and quit
Nov 14, 2009 | GMC Yukon Cars & Trucks
2007 Chevy Impala ABS Plastic Rear Lip Air Dam 179-200-2 Razzi Logo
Top Razzi Vehicle Parts & Accessories Experts
mike t.
Johnathan Lence
Johnathan Lence
Are you a Razzi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
