Voice Me voice-Activated Remote control no instructions
I have a Voice Me voice-Activated Remote control made by Hotech model vm1030, but can't remember how to programme it as I have no instructions can anyone help thank you
4 Suggested Answers
  • 36 Answers
SOURCE: cant programme Phill Jumbo Universal remote controller
it would take a week to type the book and code's.
best bet> forget the jumbo bit.google universal remote control. they are all much of a much and get info from any
Posted on Nov 04, 2009
  • 5184 Answers
SOURCE: how do i program this remote control Radio Shack
Turn on the unit to be controlled manually. Press and hold Setup until the voice prompt starts the programming menu. Press 1 to directly enter a code. Press 2 to search for a code. Note at any step if the no buttons are pressed for 15 seconds, the remote will enter the usage mode. Start again from the Setup button. When prompted, press the device button for the device you want the remote to control.
Then enter the 4 digit code (if using the direct programming mode). The LED will blink twice and the remote will announce success. Test if the remote works (play, power) when prompted to test the code and press Setup if it is successful. Then wait until the remote says goodbye and then press Power again. The unit should turn off. (I strongly suggest testing other functions as well after this.) Repeat with other codes if unsuccessful.
For searching through the programmed codes, start as indicated above: press and hold Setup and then press 2. When prompted press the device button. Then press the test key (power usually). Slowly alternate pressing CH+ and power until the device turns off. Press CH- if you miss the device turning off. Press Setup to store the code. Then after the remote says goodbye check if the remote works for all the functions. Repeat the above if it doesn't work for all features.
The manual for the remote is available here: http://files.remotecentral.com/view/852-1041-1/radio_shack_15-2146_6-in-1_easy_setup_voice.html . This file is a PDF in a zip archive and does include the code list at the end.
Please note that codes in the remotes are limited to those for devices released at least 6 months before the remote was programmed. If your device is newer than your remote, you may need a new universal remote. I suspect this remote may be from 2004.
I hope this helps.
Posted on Mar 01, 2011
SOURCE: I have a Vizio TV
For the InVoca 3.0 I used a Goldstar TV code for a Vizio TV.I'm not sure what the 3 digit code was but you can search Goldstar codes on theremote shown in the manual with a 2 digit code 33. You also can train it fromyou remote but I did not try that method. They might have different manualsbecause my manual has more instructions than the online version one.
Posted on May 07, 2011
Invoca 3.0 voice activated remote freezes up after several hours of idle time (overnight)
this another sympton from keypads dirty ,dust or worn, you can try to cleaning the keypads contacts with special spray contacts cleaner, but you must open the remote control. Otherwise will not work.
or you must go to the repair shopr, or to buy a new one.
God bless you
May 13, 2012 | Televison & Video
Common Problems with Tomy Remote Control Voice Activated Verbot Robot 5401
When I start my Verbot, eyes and mouth are lighting, in a similar way to a smile, but I canĀ“t get enter any voice command.
Is this behavior an "normal" boot for Verbot?
I tryed with sinth tones too, but nothing happens. The record light indicator is always flashing when I press it and speak..
Jan 25, 2012 | Tomy Remote Control Voice Activated Verbot...
How do i make a hands free call on my head set i have a plantronics explorer 200 series?
To use Voice Dialing:
With the headset on, press the call controlbutton for 2 seconds to activate the voice dialling.
NOTE To use voice-activated dialling, the voice-dialling feature must be enabled on your phone. See your Bluetooth Phone Manual for instructions.
Good luck from Headsets Direct!
Aug 22, 2011 | Plantronics Explorer 240 Bluetooth Headset
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a Vizio TV and just bought a InVoca 3 voice activated remote control. I did not see any manufacturers codes for my Vizio that I have to enter into my InVoca 3. Can I use my Invoca 3 with my...
Aug 17, 2010 | KNG America InVoca 3.0 Remote Control
How to turn on Olympus Pearlcorder ''voice activation'' feature?
On my model the Olympus Pearlcorder S909 there is a slide button on the end marked VCVA (variable control voice actuator). Switch it to that position then press record and away you go, voice activated recording!
Hope this helps.
Aug 27, 2009 | Audio Players & Recorders
Need manual for invoca 3.0 remote can anyone help
just google invoca and go to the manuel
then just print it thats what I did for the one I bought for $0.85
Dec 28, 2008 | Invoca 326348 Remote Control
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Bell South 2250 one seems to be voice activated and other not voice activated.
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps.
Nov 24, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Televison & Video Logo
395 people viewed this question
Top Televison & Video Experts
Electro Med Services...
