Question about Technics Audio Players & Recorders
SL-QD33 spins too fast - Technics Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Technics sl qd33
tone arm could need cleaning never done it personally but if you take it to a stereo shop they should b able to help you
Sep 19, 2013 | Audio Players & Recorders
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
A few weeks ago I sent in a question and paid the $6.00 but haven't received a response. I have a Technics SL-QD33 turntable that will play an album but only for about 5 seconds regardless of where you...
Not to be a smart a$$ but I have one too,, and I got a new needle and it was not cut right,, so I got another one and it plays great now,, I did check the weight adjustment at the rear of the arm and it was a little shy of what was needed, a half turn put it back in place and I was off and running, sorry you didn't get the paid for advice,, But this is a freebie ,, good luck
Sep 10, 2010 | Technics Audio Players & Recorders
I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT DRIVE AUTOMATIC THAT IS SPINNING TO FAST.
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Apr 03, 2010 | Technics SL-1200MK2 Turntable
I have a 91 Saturn Sl 2. The odometer spins twice as fast as it should when driving under 55 mph. over 55 it stops working altogether untill you speed up to over 65mph then it spins fast again. The speedo...
its sounds like odometer is bad,,you either gotta get a used one or send it out to get it fixed, i dont think you can get a new one from saturn anymore,too old
Oct 09, 2009 | 1993 Saturn SL2
Removing the platter to oil the motor shaft
hi .... get any object ( like hammer, or handle or wood) tap slight on the middle spindle of your turntable until become loose,...
May 28, 2009 | Technics SL-1200MK2 Turntable
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
59 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
