Question about Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support &
Pioneer DEH-X6500BT amp & speaker problems
I just installed a Pioneer DEH-X6500BT in my car and I can't get my amp to work and my back speakers sound really low. The front speakers work fine. Any ideas? Thanks!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Posted on Nov 06, 2014
  • 119 Answers
SOURCE: Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Posted on Nov 04, 2006
Cerfer39
  • 709 Answers
SOURCE: wiring speakers to bridgable amp
I just answered this one
Posted on Oct 23, 2007
zzedly
  • 300 Answers
SOURCE: Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Posted on Mar 27, 2008
  • 631 Answers
SOURCE: No audio to speakers from deck, just to amp
It's possible (probable) that the head unit has a blown internal amplifier IC. Measure the DC voltage on each of the 8 speaker wires on the head unit. Place the black lead on the chassis of the head unit. Probe each wire with the red lead. All should read approximately 1/2 of the voltage on the yellow wire. If you get some that are significantly higher or lower, disconnect all speaker wires from the harness and measure again. If the voltage is still not ~1/2 of the voltage on the yellow wire, the IC is almost certainly defective.
For the external amp, you need to check the shield ground for the head unit. The following page shows you how.
Test RCA shield ground
Posted on Apr 22, 2008
tech48
  • 624 Answers
SOURCE: Pioneer 760W (Mosfet Power Supply) Amplier
If you are connecting the negative lead of the voltmeter to the chassis of the car, and then checking the voltage at the amp on the ground power input of the amplifier, then your amplifier is not grounded properly. The amp should also be grounded on the chassis of the car, so if you have 4 V DC on it, it can not possibly be grounded to the chassis. The chassis is the same potential at any point on the car.
Could it be that the 4 V DC is at the power terminals +B or positive voltage? That would not be an uncommon thing to have since the amplifier will hold some charge after it is turned off and that would be normal.
Since you have a voltage meter, you could check the current draw of the amplifier if your meter also have a setting for current or amps.
If so, connect the meter in series with the ground of the amplifier. That means to disconnect the ground wire at the amplifier, and use the meter to complete the ground connection by putting one lead of the meter on the ground wire that should be connected to the chassis of the car and the other lead to the ground terminal of the amplifier. It does not matter which lead you connect to the wire or the amplifier, that would only make your measurement i postive current or negative current, but the meter must be set up properly for current. Most of them have a diiferent jack to put the positive lead into for current. most have two different jacks. If yours does also, choose the lead with the larger amp rating. Most have 10A and 300mA, the lareger amp rating is 10A. That is 10 amps max and the 300mA means 300 milli-amps which is .3 amps max.
Do this with the amplifier turned off and the car off. If you measure any current at that point you do have a current draw with the amp off and the amp would need to be serviced by a professional. If you have no current draw there, the amp is not the source of your battery draining. This would find out for certain if the amplifier is really draining the battery.
If you have found this information help a rating of "FixYa" would be appreciated.
If you need more help just ask,
Dave
Posted on Jun 27, 2008
I am unable to get in the Illumination mode, on my Radio. I had it set once, when I first installed it.
Pioneer DEH-X6500BT Car Stereo MIXTRAX Demo ...
? 1:30
https://www.youtube.com/watch?v=WAHM8JKdk2s
Sep 1, 2012 - Uploaded by SantaClaritaAutosoun
Brand New 2013 Pioneer DEH-X6500BT Bluetooth car Stereowith MIXTRAX, ... It seems like the cooling fins on the back getreally hot. ... I can't switch mixtrax off, even when off on the system. ... How do you make it change colors like that and can you do it on tuner mode ? ... The stereo is a din size.Missing: single
Jan 05, 2016 | Pioneer deh-x5600hd single din car stereo...
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Amp error comes on on my radio and no sound plays through the speakers of my 1997 jeep grand Cherokee Lerado
take it to a certified mechanic to check out the amp. its likely the amplifier burnt out or disconnected.
Nov 07, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I'm attempting to install a pioneer stereo into my son's 74 Chevy pickup.
it plugs in to the the plugs you unpluged from the original radio if there are no plugs then your going to have to wire it all up from scratch new power wires new speaker wires and just alot of work so I hope you didn't cut the plug off the old radio
Mar 21, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I just installed my Pioneer DEH-X6500BT for my 2004 Subaru Outback. However, the radio reception is very poor. The radio sounds very staticky
I suspect that the antenna connection is not completely connected. If an adapter was necessary, check that as well. Good luck!
Jan 20, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I wont the speakers hooked to the cd player no the amp
check were the speakers are installed for pre existing wiring they probly left it there.. if not then you will have to run speaker wire from your stereo wiring harness to your speakers. if the speakers were hooked up to the amp then the wire in the harness should be vacant and you can use it if all the wires are connected then that means that you just have to find were that wire leads and hook your speakers up to it.
Jun 03, 2010 | Pioneer DEH-P6400 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support & Logo
312 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
