Question about Sanyo DP32649 31.5 in. TV
The antenna connection broke off
On the side of the TV the cable connection was hooked up and on too tight and I tried to use pliers to get it unhooked and it cracked and broke off. How do I get it fixed?
    Master:
  • Sanyo Master
  • 505 Answers
If the cracked portion is on the cable then you need to get the cable recrimpted with another connector. You can do this yourself but this needs a special tool. Ask your cable provider to get the proper connector reapplied.
Posted on Jan 19, 2015
I bought a new antenna and new coaxial cable, but the tv screen tells me to connect antenna, why?
Hiya!
Stuff you have already done:
Making sure that the coax cable us nice and tightly connected to both TV AND antenna by jiggling it whike you screw it on
Selecting "antenna" in TV set up menu
Right?
Let me know
Nov 19, 2016 | Televison & Video
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
Antenna in port connection broke off the tv
You can purchase the whole main pcb for the tv, but this would be costly with arts and abor. You could order just the part you broke called the Tuner but, you would need to know how to solder to take off the old and put on the new one which is time consuming. The cheapest and easiest way is to if you do not have cable or sattelite and just have an over the air antenna, get you a converter bx with the composite outputs "red,yellow,white" and connect that to your tv. Thats the cheapest and simplest work-around fix. Good luck!
Jun 29, 2012 | Sylvania Televison & Video
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
No signal -Samsung HC-R4755
Well Dave have a tech come out and solder your ANT1 connection back on its a simple job that will probably set you back $50.00 or less.
May 31, 2010 | Samsung HC-R4755W 47" HDTV
I believe I broke the antenna connection on my Mintek TV.
Definitively you broke the connector. Look in the internet the web site of Mintek. But since for a technician is not a big deal to fix, you can take that TV to ANY repair service, because is very easy to do it. I strongly recommend that.
Nov 20, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Cable connector broke off of the television.
You can by an RFmodulator and a set of composite cables to get the cable signal into the tv provided you have audio and video inputs. You will then need to tune tv to the proper input to view.
Hope this helps you.
Sep 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sanyo DP32649 31.5 in. TV Logo
60 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
