Question about Acer Aspire 5100 Notebook
ENE PCI Memory Stick Reader
My memory stick reader does not recognize a memory stick when it is installed.  It worked up until a few days ago, and nothing was changed to my knowledge (windows may have automatically updated).  I have tried updating drivers, bu the problem persists.  Other cards, SD seems to work fine.  I do not know what else to do.  Please Help!!! Thank you!!!
  • 156 Answers
Re: ENE PCI Memory Stick Reader
Try uninstalling ur multimedia reader driver and then reinstall them.
Posted on Oct 23, 2007
0 characters
3 Points
I have problems with card reader is not compatible with w in 8.1 pro
Probably you need to download Driver for it to use.
Hope this Helped
Apr 10, 2014 | Sony VAIO PC Laptops
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
Nov 14, 2013 | Acer Aspire PC Laptops
UBS port won't allow my memory stick to go in is there a lock on it???
Hello !
Be certain you are trying a USB port. It is rectangular in shape. The USB memory stick will only go in one way. Try flipping it over.
If still a problem ...
Either your USB memory stick is bad or your USB port on your notebook is bad.
Try another memory stick or try a different USB port on your notebook - should determine which is OK and which is bad.
Hope this helps.
Oct 28, 2009 | Acer Aspire One A150-1006 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Sep 25, 2009 | Dell Inspiron 6400 Notebook
Windows shuts down when card reader or camera is plugged into USB
Some software programs monitor for removable drives which are not used. When you plug in your camera or memory card or memory stick, It comes up as a removable drive. My wife's laptop with Vista Home Basic had a problem between her secure memory stick and InCD. BSOD would cause restart the computer when stick was plugged in. I temporarily disabled InCD and memory stick works. Funny, though, her machine had no trouble with her camera. Go figure.
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
May 04, 2009 | Dell Inspiron E1505 Notebook
HP Pavilion dv6000 driver not reading Sony Memory Stick Pro Duo
hey i have the same problem with the hp pavillion 6000. It is one of the most unreliable computers in the world but i guess thats another discussion... I have a 2g memory card that will only be recognized if i restart the computer and put it in then... Once you eject it though it wont recognize it. HP needs to get their **** together and stop ripping people off.
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Acer aspire 5610z card reader
This is because your 5-in-1 doesn't support Duo Pro.
Feb 04, 2008 | Acer Aspire 5100 Notebook
right click on the ? and uninstall it. Scan for hardware changes and let windows find the driver.
Dec 07, 2007 | Acer Aspire 3050-1733 Notebook
Acer Aspire 5100 Notebook Logo
98 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
