Question about PSB Audio Players & Recorders
Psb speaker making static sound
Only the right speaker is making a static sound. Not sure if i should try replacing wires, fix it or even replace the whole speaker
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
Jowinson
  • 16 Answers
SOURCE: Left speaker not working...
I am supporting TIRZO by adding that you can open the left speaker case and check the wire that leads to the main speaker, I hope the fault should be from the connection between the main speaker and the green light that is on.
Jowinson
Posted on Jun 20, 2008
  • 909 Answers
SOURCE: Trying to fix an old record player - Califone.
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
Posted on May 14, 2009
SOURCE: Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Posted on Jul 14, 2009
technical114
  • 1851 Answers
SOURCE: there is static coming out of my speakers on my
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Posted on Feb 20, 2010
I have two Bose external speakers and I have developed static. How can I fix this?
Check all connections. Make them tight - doubble the wire over if necessary. Make sure you have the speakers in phase (red wire on the red cocnnector type of thing). Move the speaker wires away from all power cords.
Sep 28, 2011 | Bose MediaMate Computer Speakers
Video has sound, no picture. Occasional flash of picture
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 31, 2011 | Computers & Internet
Altec-Lansing VS-2120 speakers problem: Right speaker gives no sound, although computer checks out on other speakers, and headphone plugged into this speaker set works on both channels. Also get static...
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Aug 30, 2011 | Computers & Internet
I let a friend borrow my speakers (z-2300) and When they came back one of them fails to produce any sound. I switched the wire connections with the same problem on the same speaker (absolutely no sound....
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 03, 2011 | Logitech Z-2300 Computer Speakers
My Altec Lansing BX1021 Makes static noises when wires moved, but no sound from computer.
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 01, 2011 | Computers & Internet
I have HP GM325AA speakers and I'm using Toshiba Virtual Sound when playing music. Sound does not come out of the left speaker when I use the Toshiba Virtual Sound. Is there a way to fix this?
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps don
Mar 09, 2011 | HP GM325AA#ABA 2 Speakers
Right speaker not working
hope this helps
Jan 31, 2011 | Dell 5650 Computer Speakers
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
Has worked fine for 10 years and then this morning lost the rear speakers. All I get is a little static with very little volumn and the center speaker just has static but is a loud as the two front...
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Televison & Video
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or...
you may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Jul 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
44 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
