Question about Niles ZR-4630 2 Channels Receiver
Error Message E 01
I get error message E 01 when I turn on. It first shows radio stations and then clicks and get E 01
Wave Radio/CDll Disk Error Message
Exactly what happened with mine.. see my method for ugly-but-works fix.
"I turn the machine off, then turn it on, and lightly smack the machine on the side as it's..." (
Apr 06, 2014 | Bose & Wave& Music System
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
I disconnected the battery and when I went to turn on the radio a code came up. I did not know what this ment so I was just started pushing buttons. 3error came up. I then had my son disconnect the battery...
Disconnect the negative terminal of the battery for 3 minutes, and try again. The error message shouldnt be on when you insert the radio code, it wont work. I sure hope that the battery inside the radio didnt die, because it wont be able to retain the code, or the station presets. You will be amazed at how much better the aftermarket radios are. If unable to bring it back to life, do not hesitate replacing it with a well known brand. Most come with inputs to play pendrives and Ipods.
Jan 22, 2010 | 2005 Honda Civic
I am receiving error message of : 86:01 Possible paper jam
Most times when this error occurs it is because of one of three things:
1. Paper jammed in the carriage path that prevents the printhead from moving all the way from left to right. Check closely on the far left and right as paper can be pushed into the interior of the printer by the service station.
2. The printhead cover was not closed properly and the metal ring that that the blue handle is supposed to engage in is catching on the side of the printer.
3. The drive belt has either come off the track or broken. Open the lid and check the black rubber belt that drives the printhead assembly. It should be taunt. If it is loose there is a problem. I have had several 1100 series designjets throw their belt off the tension pulley. You can sometimes reseat it but my experience is that it will get thrown again. If you replace the belt, replace the tensioner at the same time.
Dec 07, 2009 | HP Designjet T1100ps Printer
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
What does error code (Er-EL) on a Bose sound system on a 2002 Acura MDX mean?
You can disconnect the battery, reconnect it and use your radio code to get it working again. This worked for it...it's like I 'rebooted' the cd player.
Oct 22, 2008 | Car Audio & Video
Help Toshiba E-Studio 162 Copier error
how can I reset the Toshiba estusio162 without calling for maintenance
Sep 03, 2008 | Toshiba e-Studio162 Copier
Niles ZR-4630 2 Channels Receiver Logo
Top Niles Audio Players & Recorders Experts
 Grubhead
Grubhead
Joseph Hoffmann
Rob
Rob
Are you a Niles Audio Player and Recorder Expert? Answer questions, earn points and help others
