Question about Jensen Audiovox Cnpjen1 Specific Xm Adapter Audiovox Cnp2000uca Tuner
Och1 won't recognize cnp2000uca
I installed the firmware for the advent och1 head unit, but after i plug it into the radio, the radio still wont recognize the cnp2000uca unit. The button for XM is still greyed out and it won't let me choose it. This is my second tuner and cenjen1 cord, so i know they aren't the problem.
How do I get sound on Advent L75118 laptop?
go to comp repair shop and they will fix for you its just sound hard drive that needs to be installed.
Nov 09, 2017 | Advent Computers & Internet
Can I replace the head unit in a 2004 saab 9-3 ? I've heard you can't because to car won't accept any other radios in it . I'm looking to replace it with a touch screen head unit .
Thanks for the help ...so your saying that if I for example buy a ...pioneer stereo that is the right size then it should have no problem hooking into the car with out any fancy wire work ....I'm for iliac with normal installation ( done it before ) but I'm just a little intimidated by some of the sites saying that you can't install a after market radio into a saab because it won't exempt it and all that stuff . But any right size stereo should work your telling me ?
Nov 06, 2012 | 2004 Saab 9-3
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
My computer wont detect the mp3 and connect
Is the player working normally otherwise?
If so, then try the player in a different USB port on your computer. When plugged in, the display of the Pearl should say that it is connected to a USB device and it will show up automatically as a removable external drive in your windows explorer.
If not, then upgrade the firmware in the unit and the computer will recognize it again. Download the firmware upgradefrom http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
Nov 16, 2009 | RCA TH1602 MP3 Player
Am on radio will work fm wont work
Unfortunately the FM Modulator inside the Head Unit has stopped working. The only solution for this is to replace the Head unit or install an Aftermarket Head Unit.
Jan 24, 2009 | 1998 Jeep Cherokee
96 dodge caravan windows wont roll up anymore after radio install
what do you mean by head unit? do you mean master control switches on drivers door panel?
Jan 21, 2009 | 1999 Dodge Grand Caravan
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
i got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Nov 19, 2008 | JVC KW-AVX810 Car DVD Player
Jensen Audiovox Cnpjen1 Specific Xm Adapter Audiovox Cnp2000uca Tuner Logo
43 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
