Question about Propellerhead Reason 4.0 Upgrade - Windows and Mac Upgrade Version for PC, Mac
Slaving Reason to the MPC 2000xl using the MOTU Micro Lite MIDI Interface. But also using an external keyboard (Korg Triton Xtreme) as a controller for the Reason MIDI sounds, while still having the Triton slave to the MPC 2000xl which it normally does when I'm not using Reason or the MOTU Micro Lite. This way I can simultaneously use the MPC to channel MIDI from Reason & record a sequence in the MPC, while also channelling MIDI from Reason through my Triton (as a controller), but still having the ability to record/syncing my Triton to the MPC. Is this possible?
3 Suggested Answers
  • 729 Answers
SOURCE: Reasons won't record midi data
Hi Danadepatter,
You have to check were the problems is, with exclude way.
1. you first find out if your "master keyboard" really works: Try to run another program where you can run the the keyboard(you can use a trial and the uninstall it after)
2. if that works then it is another place not the keyboard, then it can bee the program / sound card / configuration . you can find the reason manual here :
http://www.scribd.com/doc/13823619/Reason-4-Manual-English
Check if the configuration to the midi keyboard is ok.
FOR THE SOUND CARD: be sure that you do not have anything else that can interrupt the sound card. Shut down other recorders and other software that use the sound card and bee sure that you use the same sound card configuration (normally it is realtec the default)
If nothing happens please go to the support here for Reason software :
http://www.propellerheads.se/company/contact/techsupport/index.cfm?fuseaction=get_article&article=reasonsupport
Hope that helps
Have a nice weekend
Please rate my answer
Posted on Sep 25, 2009
GodBlessU
  • 3513 Answers
SOURCE: i have a mac os
Try this. First Edit > Preferences > Page: Audio > Audio card drive : that should fix it. If there is still issues check for the audio card drivers.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 17, 2010
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
How do I play the O1WFD sequencer through the Triton Pro X??
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
May 16, 2010 | Music
MOTU Ultralite MK3 Hybrid and Mac: Midi doesn't work anyway. Impossible to configure Midi
resister your product by motu. then download your update driver.then try, you can use another usb midi device, this is best way
Mar 27, 2010 | Motu UltraLite FireWire Audio Interface...
Triton Le
when you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Feb 18, 2009 | Korg Legacy Collection
Trouble with hooking mpc4k and korg triton pro to mbox
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
let me know if you need any more help.
Feb 16, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Recognizes the midi interface but not the keyboard
Sir,
I am using lenovo system IBM & this system format, but sound card not match this system.  You are requested to please solve the problem.
Dec 23, 2008 | M-Audio Audiophile USB Audio and MIDI...
Motu micro lite
Log into Motu.com with  UN - fixyajames PW - fixya
Hope the download fixes the problem.
James Mac
Sep 09, 2008 | Motu Mark of the Unicorn Micro Lite USB...
I have a triton LE Korg workstation. I have the MIDI interface cables from Yamaha. I would like to record straight to my computer using these cables. Is this possible?
Hi
Yes it is possible if you have a MIDI breakout lead. This lead plugs into the game port on the back of your sound card(if you have one) If you do not have a game port, then you will need a midi interface that can be plugged into your PC via USB port. USB Midi interfaces can be bought from most music shops.
What does the lead that you have look like? If it has a 180 deg 5 pin DIN plug at each end then you have a standard midi connection cable. Useful only for plugging into the MIDI interface I just mentioned. If you have any questions about this,I am happy to help you out. A "FixYa" rating would be great for my advice and future efforts to help you resolve this:)
regard
Graeme
Mar 15, 2008 | Audio Players & Recorders
Propellerhead Reason 4.0 Upgrade - Windows and Mac Upgrade Version for PC, Mac  Logo
391 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
solver2010
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
