My brada front load dryer has childlock on - Washing Machines
Where can I order Parts For A Brada Dryer
Hi Armand,here's a link to some control knobs,if these are not them,let me know and I will search more.You can give me your dryer's model number. Samsung Dryer Knob Dial Button Parts
Feb 08, 2016 | Dryers
I have a brada dryer that runs for two minutes then shuts off. It shows a code . I tried my braker switch didn't help. Cleaned it all out and still the same.
Brada Appliances Product Support ' ManualsOnline.com
www.manualsonline.com/support/brada/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Sep 30, 2015 | Dryers
My Brada dryer won't turn on again for about 30min after only drying one load.
SOUNDS LIKE COULD BE A BAD MOTOR WINDINGS PROBLEM? If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Feb 15, 2015 | Dryers
Belt Diagram for Brada Dryer
Call the manufactor to send you one for your machine.
Jan 02, 2013 | Samsung ASSY DOOR;BRADA-DRYER -...
Padlock near timer
This means Childlock is on..Think you hold in for over 10 secs to switch off
Mar 24, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
HOW DO REPLACE THE HEATING ELEMENT OF THE BRADA BED70W DRYER?
There is a video on YOUTUBE on the complete disassembly of the Brada. Follow that to access the heating element for removeal. You can also remove the discharge piping on the back to access the heating element electrodes. remove the wire clips and put an ohm meter accross. you should have some kind of resistance on the meter. There is also a video on how to use an ohm meter.
Mar 08, 2011 | Dryers
Brand new siemens w/machine childlock stops me programming
I think you press and hold for 10 secs to unlock, consult manual to make sure...
Oct 02, 2009 | Siemens WFXD8400UC Front Load Washer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
