Question about Kenwood Food Mixers
Beater broke off in mixer. Kenwood major model A 717c
Beater broke off in mixer, can not remove the broken piece..may need a new gear box? What do I need?
3 Suggested Answers
mirran
  • 515 Answers
SOURCE: Kenwood Mixer A702
There are not any new parts from Kenwood to A700 series, try to find it on internet or if anyone in the forum has one.
Posted on Jul 12, 2008
alexpomar
  • 26 Answers
SOURCE: broken kenwood mixer (major)
Please tell what happen with your Kenwood maybe can help from here .
or call this people
Kenwood Home Appliances (Pty) Ltd
1295 Clubhouse Street
Maraisburg 1709
South Africa
+27 (11) 4740153
Regards
Kenwood Chef Restore
Posted on Jan 22, 2009
Professional 600 575 watts beater shaft is loose
If the beater shaft that you attach the beater to is loose in it's housing, then you will need a new planetary for your mixer, it is a relatively easy fix to make, but you will have to order the part before you can effect a fix.
The 600 model has the center shaft attached to the planetary by means of a heat pressure press in. Which means that when the colored rotating part starts to come loose that you have to replace the whole planetary piecec994bebd-6a21-41c8-821e-a90ec9e3ea14.jpg
the piece that the beater attaches to is called the agitator shaft and it will need to be removed and put on to the new planetary when you install the new one. If the agitator is actually the piece that is loose then you need a gear at the top, a pin underneath of the gear, or a snap ring that holds the shaft together in the planetary housing. Go to the kitchenaid address listed here>> http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
when the page opens look on the left side of page and fill in the proper model number (it is on the bottom of your mixer on a white tag), the page will give several choices go to the parts list section and click on that choice for your model number, (you will need the proper part number to order the correct color for your mixer, by following the parts list diagram you will see that there is a very understandable process that you can follow to open up the mixer and replace the planetary, hope that this helps, let us know if you need assistance or if this answered your question
Apr 17, 2013 | Food Mixers
Kenwood chef a701 beater shaft is broke can i buy a new one
yes go to kenwood web site look for dealers who still support a701 mixers.
Apr 06, 2010 | Kenwood KM800 Major Classic Stand Mixer
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Feb 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Broken kenwood mixer (major)
or call this people
Maraisburg 1709
South Africa
+27 (11) 4740153
Regards
Jan 07, 2009 | Kenwood KM800 Major Classic Stand Mixer
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood Mixer A702
Jul 07, 2008 | Kenwood KM305 Stand Mixer
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
54 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
