Question about Yomega Gamma Brain Wing with DVD
My yo-yo won't sleep or run smoothly!
Everyone who knows yo-yos know there are several ways to yo; two of those ways use 1) a fixed axle or 2) a transaxle. The Yomega Gamma Brain Wing has both, with a gear that switches between the two. The fixed axle keeps in place so that the yo-yo goes right back to your hand; the transaxle is for "Sleeping" which spins the yo-yo at the bottom until the string is tugged by the user. My Wing will not sleep whn the gear's on that function, and makes a strange sound with the other. I have now taken apart the Wing, and I think the axle has gone too far in and has possibly damaged the yo-yo. I am lost as to what to do to fix it.
Ok everyone I have an off brand bike it's a johnny
sounds like a broken or missing keyway in the clutch hub/on the main shft
May 07, 2013 | Motorcycles
Tip
Anion sanitary napkins
Because the "Aion" could be release of active oxygen and improve lung function, promoting metabolism and enhance immunity, improve sleep, and other functions, and won the "air vitamin" "longevity of" reputation. The negative ion chip in contact with the blood will release more than 6100 / cm3 of negative ions, can remove the body of harmful bacteria and odour of gas molecules for comfortable, clean and exception of smell role.We put 1 colpitis self-checking card in each bag,for the customer self-testing and contrast color card to know if has colpitis.
8 Effective:
Increases energy
Inreases physical stamina
Reduces pain
Balances blood pressure
Eases breathing
Smoothes skin
Cholesterol regulation
Weight loss
Relieves tension
Reduces inflammation
Improves sleep patterns
Relieves joint stiffness
Speeds recovery time from injuries andsurgery
Enhances immune system
on Apr 15, 2010 | Audio Players & Recorders
How can I smooth out my waterbed? There are several wrinkles and I don't know how to fix it.
If you plan on doing this yourself, you should read over the following article on smoothing out baffles. If that doesn't help you may want to do a little more research.
http://www.ehow.com/how_7877769_smooth-baffled-waterbed.html
Jul 24, 2012 | Furniture
Want to know the carburettor L and H screw adjustment of Makita Power cutter DPC 8132
On both screws, turn them in just until they seat, not tight. Back them out one full turn. Start the motor and let it run until it gets up to temperature. If it won't start or stay running, turn the L screw out another 1/2 turn. With the motor idling, turn the L screw in just until you hear the motor tone change then back it out until it smoothes out and keep going until the motor tone changes or starte running rough. Turn it back in half way between these two points. With a blade on the saw, hold the throttle at about 1/2 to 3/4 full and adjust the H screw using the same method.
Feb 16, 2012 | Saws
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
How to adjust the carburtor high and low on my weedeater head cutter?
Hi jamesbj44...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know when you go to replace them.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position to start with...you re-adjust when the engine is warm turning the screw in or out till the engine runs smoothly.
The high speed jet is normally adjusted to 1 1/2- 1 3/4 open from the bottom seated positon, then re-adjusted to run smoothly when running at high speed by turning the screw in or out.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
Hi i have a 1991 pre div xj600 problem is its been stood for 8 years starts but only runs on 2 pots first time it ran on 2:3 cleaned out carbs reffited now runs on 1;4 so now i dont know which way yo go...
You need a complete tuneup including carb rebuild. Rubber parts deteriorate, gas evalprates and cloggs. Who knows what happens in the oil sump??? Battery looses 1% per month sitting which is 96 % according to the math.
8 years is a long time
Oct 04, 2009 | Yamaha XJ 600 Motorcycles
My iphone does not always wake up when a call comes in. When I wake it up it shows a missed call. Is there a way to fix this?
1- Turn off the 3G Feature:
U will find it in Settings -> General ->Network.
2- In case if u have upgraded ur phone to version 3.0.1
Go to Settings -> Mails,Contacts,Calenders -> Fetch New Data.Turn off the Push feature, And for the fetch option select "Manually".Now under the fetch criteria click on advance .Here u can c a list of added addresses.Now set the settings for each address to 'Manual' instead of 'Push' or 'Fetch'. Now again go to settings and turn of Notification feature.Hope it helps :)
Aug 07, 2009 | Apple iPhone 3GS Black (16 GB)
Remove alternator on 03 ford escape
2001 ford escape. I have done this three times:
Loosen lugs, and spindle nut on axle. Jack up vehicle. Remove tire. Remove brake caliper, pads, bracket, and rotor, secure caliper away from work area. Pull abs sensor connector from tire well, disconnect connector. Remove abs wire from tire well and brake bracket. Remove tie rod from spindle assembly. Remove pinch bolt form lower ball joint. remove nuts from strut bolts. To remove the spindle: 1. Separate ball joint and pull strut bolts 2. pull bolts and pull off ball joint. the second way may not work SAFELY on some vehicles. The axle is removed by two nuts on the intermediate shaft bearing. Pull out axle. Remove alternator and bracket.
Here is the tricky part: the alternator comes out through the hole where the axle was. I found that jacking the front of the motor up helps and position the alternator pulley up, two bolt holes out, fight it from there, careful not to stick the studs from the axle bearing into the case. May take a LITTLE prying. Once you get it it will just drop
Mar 24, 2009 | 2003 Ford Escape
Yomega Gamma Brain Wing with DVD Logo
23 people viewed this question
Top Yomega Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Yomega Toy Expert? Answer questions, earn points and help others
