Question about Zynga Texas HoldEm Poker
Unfortunately the app you're using hasn't been set up correctly by the developer, and we can't process its requests. Please contact the app developer about this issue.
I'm trying to purchase chips but the alert "Unfortunately the app you're using hasn't been set up correctly by the developer, and we can't process its requests. Please contact the app developer about this issue." keeps appearing.
My new trackfone keeps saying Unfortunately, the process com.android.phone has stopped. It happened after I used the activation card.
Send it back. The phone app (yes the phone is an app) has stopped. It's a software problem.
Apr 15, 2017 | Cell Phones
Could you please add shqiptv app on roku2?
You would need to contact roku and request that they develop a compatible app or contact the app company and request that they develop a roku app. Roku uses itsown pproprietary operating system.
Jan 25, 2017 | Internet Computers & Internet
How can I remove "unfortunately the process com.android.phone has stopped"There is no way I can access my tablet.
settings ->application manger -> all-> and clear data on contact and contact storage in app manager.
!!!: YOUR DATA FOR CONTACTS WILL BE DELETED.
Dec 29, 2014 | Samsung Galaxy Tab 101 Tablet...
Why do I keep getting "force close"
I'm not quite sure why are we getting this "force close", cause its app dependent. However i can suggest you the following
Most often, force close messages are caused by the app accessing corrupted data. For one reason or another, the app expects a certain bit of data to be available and can't access it. Since the program isn't programmed or "told" what to do in such situations, the result is a force close. In these cases, you can usually clear the problem by going to "Settings > Apps > app name > Clear data". If doing this doesn't work, you may want to contact the developer of the app for advice.
Jul 13, 2014 | net10.com
On my Huawei MyTouch Q phone the com dot huawei dot mytouchlauncher app keeps stopping unexpectedly whenever installing new apps
Resolution Steps App previously worked
If the app that is showing errors has previously worked and not been updated, follow these steps:
  1. Think about the pattern of what you were doing when the device froze, and what programs were open in the background. Use the answers to focus on device functions or apps that are not working correctly.
    Note: If the problem is related to more than one specific app, see: Device is slow / freezes / restarts / or displays memory errors: Android
  2. Check the docs for your device to see if there are any specific instructions for it
  3. If the problem is related to contacts or an 'android.process.acore', back up your contacts:
    1. From the Home screen, press the Menu key.
    2. Touch Settings.
    3. Touch Accounts & sync.
    4. Turn off all synchronization to Google accounts and T-Mobile Contacts Backup.
    5. Return to the Home screen.
    6. Open the App menu.
    7. Touch Contacts or People.
    8. If there are any contacts listed, they are stored on your phone (because you turned off the ones synced). From the menu, export them to the SD card to save them.
  4. Clear the app cache and data:
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Touch All.
    6. Select the application that is having issues.
      Note: For the following errors:
      • android.process.acore: Select Contacts storage.
      • android.process.mms: Select Messages.
      • com.google.process.gapps: Select Download Manager or Downloads (At the bottom of the list). Make sure the Downloads Manager is enabled. If it isn't, enable it before proceeding.
      • TWlauncher process com.sec.android.app: Select TWLauncher.
    7. Touch Clear data and Clear cache if they are available. This resets the app as if it was new, and may delete personal data stored in the app.
  5. If you turned off sync, return to Accounts & sync and turn it back on. If necessary, import any contacts you exported to the SD card.
  6. Uninstall all third-party party task managers, battery saver, or apps that close programs. For information, see Manage Applications: Manage memory on Android.
  7. Restart the device.
  8. Open the app to test if the problem happens again.
  9. If the problem recurs, uninstall the app (if possible).
  10. Wipe the cache partition to clear system memory.
    Note: To find steps for your device, search Support Community for: wipe cache [device name]
  11. Open Play Store, and re-install or update the app.
  12. Open the app to test if the problem happens again.
  13. If the problem recurs:
App never worked OR app received update and stopped working
If the app that is showing errors never worked OR was updated and then stopped working, then follow these steps:
  • If the error is with a pre-installed app, then look for more content in your device space or user manual.
  • If the error is with third-party apps, then contact the app developer. T-Mobile does not support third-party apps.
Mar 19, 2014 | Cell Phones
I cannot log into facebook on my phone
First, make sure that you are using the latest version of the Facebook application. If you are using the latest version but are still experiencing issues, try removing and then re-installing the most upgraded version of the application.
If you still experience issues, and are using the Facebook for iPhone or Facebook for Android application, please click here to submit a report.
Unfortunately, Facebook cannot provide any support for applications built by external developers. For any other application, please contact the appropriate developer. If your application has a Facebook Page, you can contact them via the "Contact Developer" link on the left hand side of their Page.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 05, 2011 | Palm Facebook Apps
Develop for iPhone
You will need an intel mac and App;e's development kit, XCODE which is free.
http://developer.apple.com/iphone/program/
Mar 18, 2009 | Apple iPhone Smartphone
MC9090 driver
The MC9090 does not require any installation.
All it requires that you have ActiveSync installed on you PC. That can be downloaded directly from Microsoft. got to www.microsoft.com and just seach for activesync.
Just make sure that the MC9090 is configured to comminicate via USB
Settings >> System >> USBConfig
Make sure it is set to [USB Client Mode].
Also
Settings >> Connections >> USB to PC
Make sure that [Enable advanced network functionality] is ticked.
If you need any more help dont hesitate to contact us
www.biastechnology.com
helpdesk@biastechnology.com
Nov 04, 2008 | Symbol MC9090-S Barcode Scanner
Zynga Texas HoldEm Poker Logo
523 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
