Question about Ski-Doo 2007 Summit Adrenaline 151 800R Power T.E.K
Summit 800r ptek 2007 flashing code oil and highbeam lights (pause)
Flashing code pause and oil lamp and highbeam
2 Suggested Answers
  • 35 Answers
SOURCE: im installing a new motor in a 2011 ski-doo summit 800r powertek, and have 3 plugs coming out of the stator only could find where two go is the 3rd for nothing or am i missing something
You are missing something. It's been a year or so since I've done this but all three of those plug back into the main stator connector that is on the right side of the machine behind the exhaust if it was installed. I thought they were all the same color though. Reply here If you haven't solved this and I'll take some pics to help you out.
Posted on Feb 13, 2015
Chain adjustment
The Chain is adjusted by way of an Internal Chain Tensioner located inside the Chain Case. Be careful it is full of oil....
Jan 04, 2014 | Ski-Doo 2009 Summit X 154 800R Power T.E.K
What does red flashing light on front of tv mean?
It may be the lamp light indicating a lamp has failed--model listed here does use a lamp.
Also look at the blinks to see if a specific number then a pause and repeats, if that then that is a error code.
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Engin light is on how to check codes
To check for trouble codes turn the ignition switch to run for three seconds (one second pause after the fuel pump stops running) and then turn the switch back to off for three seconds. Repeat this process again. Now turn the switch to ignition and wait for about 8 seconds and the check engine lamp will start flashing the codes. If there are codes present the light will flash rapidly (about three per second) then there will be a 2 second pause with the lamp off. The lamp will then flash one or more times to indicate the first digit of the trouble code. It will be on and off for about 1 second. Count the number of times it flashes for the first digit of the trouble code. Then there will be about a 2 second delay then will flash again for the second digit. After flashing the second digit there will be a 2 second delay and additional trouble codes will be flashed. Write down the numbers and when they start repeating themselves the trouble code transmission is completed. All trouble codes consist of two digits.
If the lamp flashes only the 3 flashes per second there are no trouble codes present.
If there are codes present, let me know and I can advise you of their meaning.
Oct 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Bill
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
1995 eagle summit "Check engine light"
Hi
I know on the Talon model, if you cycle the ignition switch ON OFF ON OFF ON within 5 seconds, then the power loss/check engine light will flash out the ALDL trouble codes with a 4 second pause in between each trouble code as follows:-
lets say for instance trouble codes 23 and 45 were stored. They would be displayed like this:-
lamp illuminates for 2 to 3 seconds as a bulb check then goes out
lamp then flashes 2 times, pauses, then flashes 3 times
4 second pause
lamp flashes 4 times, pauses, then flashes 5 times.
Worth a try?
Regards
Geordie
Jun 12, 2008 | 1995 Eagle Summit
Sony grand wega
Is there a light flashing on the front? If you are getting a lamp light flashing you may need to order a lamp, that is a +/- $300 proposition. If you have a light flashing check for a repeating pattern, like codes on car flashing the check engine light. It may blink like 6 times successively then pause, then blink 6 more then repeat, this is a code 6, the codes will give some Idea of what is wrong (P.S. usually code 6 is a bad thermal fuse for the lamp on most Sony PROJO LCD's and would have to be changed out by a Technician).
May 22, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Ski-Doo 2007 Summit Adrenaline 151 800R Power T.E.K Logo
64 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
