Question about Sony VAIO Notebook
Laptop won't turn on.
My Sony VAIO won't turn on. The battery is charged and I've tryed taking the battery out for a few minutes and putting it back in. It still doesn't work.
    Problem Solver:
  • 12 Answers
Open the bottom pull out the ram , and bios batt, leave for 5 min, replace, shud solve it
Posted on May 18, 2009
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: sony vaio blank screen
pls consider changing ur RAM issue will be resolved most likely ok let me know , there is strong chance ur RAM is faulty, if power comes but unable to start the system u see blank screen and no hard disk activity and light blinking then it is the RAM issue
pls rate me if i solved ur problem or explain ur problem in detail
Posted on Feb 27, 2009
romsky79
  • 822 Answers
SOURCE: Laptop Battery Wont Hold Charge
change original battery. check dc jack charger.
Posted on Jun 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My Sony Vaio laptop turns off constantly. It
When it is running I need to know if the air coming out of the vent slats is hot or just warm. It sounds like the laptop is overheating and shutting down so it doesn;t burn itself up. Get a can of compressed air they sell at office supplt companies and use short bursts of air in the vent slots and fan housing. If there is an access panel on the bottom that allows access to the processor and heatsink, blow that area out too. Then check the Sony support site and see if they have a BIOS update for that model computer. Some manufacturers are writing new BIOS instructions for their laptops for the fans to run longer and faster to take care of heat issues.
Posted on Sep 07, 2009
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
My vgn-fs742/w laptop is not powering up
Can you charge it ?
If Yes, you might have run out your battery, please charge it for at least 5 minutes, then try again to powering up.
If not, have you try to pull out your laptop battery and then plug the charger to your laptop then hit the power button ? is that laptop can boot up ?
if Yes, you might need to replace your battery
If Not, you can bring that laptop to service center :D
In some case, if after pull out baterry and laptop can boot up using power adapter direclty, you can put it back the battery to the laptop and the laptop will turn on normaly
Nov 15, 2012 | Sony VAIO VGN-FS810/W Notebook
My vaio laptop powers off when unplugged. I replaced the battery but now it won't powerup at all.
I've run into that before.....you likely have one of those that do not, in fact, work with their 'extended-life' batteries....or it is a Bad one.
Call them back and send it back / exchange for a regular one.
Tallon41
Aug 21, 2012 | Sony Vaio VPCF1390x Quad Windows 7 Home...
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
My Sony Vaio VGN NW225F laptop won't start up. The green power light goes on but the monitor is black. I tried turning it on with the battery as well as the ac alone. At one point the screen turned...
try to connect your laptop to an external monitor. if it displays on the external monitor, then your screen is bad. if it won't show up on the external monitor, then your video card might be bad. here is another idea, i don't know if its true or not, i saw a link on the internet, where is says to take out your RAM and clean it very good then put it back in and try out your laptop... hope this helps
Aug 12, 2011 | Sony Computers & Internet
My sony vaio cannot open, even battery is charging or plug in, i cannot power on the button? what is the problem please help... thank you
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Jul 16, 2011 | Sony VAIO VGN-FJ180P Notebook
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
Shuts down quickly on fully charged battery. Battery problem or laptop problem?
Most likely processor problem. If battery is good and power supply is working.
Oct 06, 2009 | Sony VAIO VGN-AR150G Notebook
My vaio turned off suddenly an the side light was blinking when i was trying to turn it on. Now i doesn't even turn on.What should i do?
Hi There !!
Thank you for choosing fixya.com
It's could be because of two reasons.
1. The Laptop is Overheated
2. The battery of the Laptop has some problems.
To diagnose this:
Step 1: Let the computer, be turned off for 15-30 minutes. Unplug the battery, Unplug any external Hardware connected to the laptop. Could be any external drive or any thing.
Step 2: After 30 minutes of disassembling the laptop. Let's put the battery back in & don' plug the power chord. Just give it a try to turn it on without plugging it in to the power jack.
Step 3: Still no joy, Try to plug the power chord back again & try to adjust it. Because Power port detects the power cord only after much adjusting of the cord and putting a weight on top of the cord so that the cord somehow makes contact with the power port on the laptop.
This is really the case with Vaio & Acer laptop because of their complex design.
Step 4: Check the voltage of your CMOS battery. if your battery is low it will fail to power up the system. if you leave it sit for a long period of time, it may be having a chance to "recharge" itself. This step should be done by a professional, because you might damage other part of the machine .
If your computer in warranty, Call Vaio Helpline right know. And, if any chance your computer is little old dont call Vaio help line because they charge heavily. Contact the local tech shop, even for your reference http://www.compusa.com/ it's cheap & good service dealer for laptop.
Hope this'll direct you in the right direction.
Sep 03, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
No screen and no sound power and battery indicator is on but hard drive indicator is off
Unplug the power adapter and take the battery out. After a minute, plug them back in and push the power button.
Jun 25, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Sony VAIO Notebook Logo
77 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
