Question about Canon Selphy CP510 Thermal Photo Printer
Canon Selphy 810 No paper or cassette incorrectly inserted
Changed color ink cassette and afterwards paper was not anymore transoported
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check lid sensor is correctly pushed or not
Posted on Dec 29, 2013
SOURCE: Need manual for Canon Selphy DS-810 Printer'help is needed asap''
plese help i need a manual for conon selphy ds810 printer.please sent so i may print my computer
Posted on Apr 29, 2009
  • 127 Answers
SOURCE: Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Posted on Jul 10, 2009
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
pineworks
  • 4041 Answers
SOURCE: Selphy DS 810. Shows error code 5100. I want to
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Only gave it a go
All The Best: Pineworks
Posted on Jan 28, 2010
  • 1739 Answers
SOURCE: I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Posted on Dec 17, 2010
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Paper size incorrect selphy cp780
i have selphy cp910 coming option paper size incorrect why.pls can you any solation
Nov 05, 2013 | Canon SELPHY CP780 Thermal Photo Printer
Keeps saying paper cassette no set correctly or objects blocking path
I was also stuck with this error message for a while. It turned out to be a 4x6 photo paper got stuck in back in a place that was not easily visible. I had to detach the double-sided paper module from the back, tilt the printer on its side and reach in with fingers and pliers to pull it out. The error message was correct, that something was blocking the cassette tray even though you could push the tray all the way in!
Jan 31, 2012 | Epson Artisan 800 All-In-One InkJet...
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
I have the paper in and replaced ink carr. and it is saying no paper or cassette incorrectly inserted
try to see if there is a paper jam.
If not try putting the paper back in and pushing it up against the back so it fits snug.
Also try taking the ink out and putting it back in.
Feb 22, 2011 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Dec 17, 2010 | Canon Office Equipment & Supplies
CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
May 18, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Jul 08, 2009 | Canon SELPHY CP740 InkJet Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
846 people viewed this question
old marine
old marine
