Question about Tools & Hardware - Others
Staple is jammed
Gun will not staple because I believe a staple is jamme
    Sergeant:
  • 393 Answers
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Posted on Jan 01, 2014
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
lessmith49
  • 5 Answers
SOURCE: see above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Posted on Feb 12, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
My arrow staple gun jams every few staples even thought it has a ''jam proof mech''
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Nov 10, 2009 | Arrow T50P ARROW STAPLE GUN
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
How to remove jammed staples in staple gun?
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
Nov 17, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
273 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
