Question about Dream Maker Spas Dream Maker Spa - X400 Silver with Cover
My jets on the left side of my hot tub barely move any water. I have rotated them several times in both directions with no success. What could be the problem?
  • Dream Maker ... Master
  • 1,383 Answers
The valve handle that controls them on the edge of the spa might be stripped or stuck
Posted on Feb 25, 2014
The soap doesn't dissolve and sometimes the plates are still dirty.
Start dishwasher. Stop after a minute or so. Check the water level in the tub. On a older model I would expect about 2 inches of water in the tub. About 1/2 inch or so below heater.
If water OK than I assume you can hear the pump running.
If pump running and enough water than I would assume a blocked wash arm.
  • First rotate by hand and make sure that it doesn't bind or interfere with rack.
  • Check carefully the holes at the ends of the arm looking for debris that collects. Seeds and such love to collect at the tips preventing the jet of water that provides the rotation force from escaping. Use small tweezers to grab debris and pull through hole
  • Blocked water return screen. Look for clear plastic etc that covers the return of the water to the pump sump.
  • Place small cups right side up in upper and lower rack. Cycle machine for a minute or so. Confirm cups are filling with water!!
If all checks OK than try running water at sink for several minutes to confirm water is very hot. Start cycle knowing inlet water to dishwasher is hot. Evaluate results.
Dec 09, 2015 | Kenmore Dishwashers
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Maax sa9592 06
Each bathtub has at least one air control on the tub that when opened lets air into the jets that produce the bubbles.
If you are experiencing too much pressure out of each jet, some of the jets if they are adjustable you can turn them down by rotating them left or right.
The other issue may be the water depth in the tub before you are turning it on. Make sure the water level is at least two inches or more above the highest jet.
Rod
US Parts Center
Feb 05, 2014 | Home
Hot tub is leaking
How severe is the leak?
Is the water level dropping when the tub is not in use? If so you will need inspect the back (inside the tub) portion of each jet. There is a gasket and nut on the backside of each jet body, these may come loose for crack.
If your leak is only when you have the pump running, your leak could be on the suction or discharge side of the pump. Only leaking when there is water pressure.
A temporary fix is Fix-A-Leak - a water treatment that will temporarily repair any crack up to 1/8". Its no guarantee but might help.
Sep 27, 2012 | Pool & Spa
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a 16 amp Legrand electrical timer cat 037 30 on my hot water system. How do I program it?
Legrand 037 30 is vertical analog timer similar to hagar EH 010
Open following link for illustration how to set and wire timer.
http://waterheatertimer.org/images/EH-010-2-2-500.jpg
Hours of the day appear on timer dial as you rotate dial around.
Hagar timer you push segments left for ON times, and right for OFF times.
To set current time, manually rotate 24-hour timer dial until current time lines up with mark.
You can also move some of the segments to the right and leave rest of segments to the left.
Then manually rotate timer dial several rotations with thumb while listening to the hot water system turn on-and-off, or use tester to test power at terminals 3 and 4 or use tester at hot water system.
If timer has override lever, then move lever to each position and repeat test by rotating dial with each switch setting.
Jun 30, 2011 | Hardware & Accessories
I have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Mar 13, 2010 | Home
Dream Maker Spas Dream Maker Spa - X400 Silver with Cover Logo
356 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
