Question about Samsung HCN653W 65" Rear Projection Television
Loose Connection for the Green Signal?
I have a Samsung HCN653W, which has worked great for the 5 years or so that I've had it. Recently, the picture began flickering, then going completely red (that is, you could still see the image, but everything was in shades of red). Occasionally, the picture is fine, and then will flash to red, and then sometimes it will come back to normal, briefly flashing green in the process. We had a tech come out to try repairing it, and he said that the lead to the green gun was loose, and he re-soldered it. It worked great for about a week, and now we are back to the same problem. It seems that walking near the TV or even an upwards inflection in the voices of spmeone on the TV can cause the picture to flicker. I plan to take it apart soon and look for more loose connections. Does anyone have any suggestions for where I should focus my search, and are there any special precautions to take (do I need to discharge any of the CRTs to make these repairs)?
  • 2 more comments
  • John May 20, 2009
    Thanks for the quick reply! Unfortunately, it is already out of
    warranty to the best of my knowledge. Also, the troubleshooting is on
    hold for a bit, because the TV seems to be (magically) working for the
    most part with the recent change in Weather here in FL (went from very
    dry and hot to cool and rainy with high humidity). though I have some
    background in electronics (computer engineer), this will be my first
    attempt to repair a TV, so if it seems to go beyond my abilities, I
    will just have to weigh out either a shop repair or a new set. In the
    mean time, I am reviewing the service manual for the TV, especially
    with regards to the screen/focus block, until the problem reaches a
    point that it is regularly producible again.
  • John Jun 22, 2009
    Ok, I finally managed to get the TV apart and start poking around. I started looking for obvious signs of damage, and did not notice anything. I did investigate the focus block a bit. I first tried adjusting focus for the green with no results, so I returned the pot to its original setting. Since the problem seems to be triggered by vibration, I began lightly tapping on the focus block with the insulated back of a screwdriver. I noticed that the green CRT did tend to go on and off as I tapped here, but as the TV began to warm up, it was less likely to flicker on and off by tapping here. I also tried tapping on the steel chassis mount that holds both the focus block and the CRTs, and once again had mixed success when tapping near the green CRT. I decided to try wiggling the wires going to the green CRT board, and it seemed that only more vigorous shakes that caused the board itself to wiggle were causing the CRT to turn on and off, so I tried tapping on the very edge of the green CRT board with the most gentle of taps, and this caused the picture to flicker every time.
    I guess my question now is:
    Does this seem consistent with a dying CRT, or is it possible that something less sinister like a bad CRT socket may be the culprit?
    I am including a link to a few pics including one that shows what the TV's picture looks like when it is at its worst. I uploaded them to Flickr due to the large size (I appologize in advanced for any inconvenience):
    http://www.flickr.com/photos/25696366@N06/sets/72157620154549658/
  • John Jun 24, 2009
    Hello again Jongar, and thanks for the quick reply! I got a chance to open it up again, and I tried tapping on various things again using a pencil eraser paying very close attention this time to the neck of the CRT. It seems that although I can get the CRT to flash by tapping on the neck, it does take a moderately hard tap to achieve this, especially when compared to the surprisingly gental touch it takes on the board to cause the symptoms.
    It also seems that tapping along the plane of the board (x&y axis) yields more results than along the z-axis, especially when tapping on the edge of the board or on a component near any corner of the board. When the CRT comes back on, the screen does flash bright green for about a half of a second or less before the picture settles at a normal color balance.
    I did notice a very small ammount of some substance on the green pcb, though it does not appear to be coolant but rather some flux from the previous repairs. No components appear to be singed, bulging, or showing any other signs of damage, but I did notice that a connector seems to be loose. CN503R, which connects the red CRT board and Dynamic Focus Block to the Green CRT board, is tilted at a bit (though barely noticeable) compared to its neighboring connector CN502R. I tried to get the connector to seat properly, but it was a bit stubborn, and I was hesitant to apply too much force with the board still attached to the CRT for fear of stressing or breaking the CRT neck.
    I would like to remove the CRT board to seat the connector but I am not sure how it is attached. Do I just need to pull the board straight off of the CRT, or does it lock into place somehow?
  • John Jul 12, 2009
    Ok, one of my Uncle's co-workers who used to work on TVs offered his assistance (which is great, because without seeing the work done before, I was not perfectly comfortable removing the board or discharging the CRT...). Right away, he noticed the same lovely cold-solder joints that I noticed (compliments of the last repair tech...). He re-touched those joints, and there was an instant improvement, but the problem was not 100% fixed. After spending a fair ammount of time inspecting it and re-soldering several questionable joints, he decided to do pretty much a global re-solder on the board. This seemed to do the trick, as the green CRT remains on now as it should, and no ammount of tapping/wiggling the board was able to change that :-)
    I still do have the wavy vertical (almost but not quite a herring-bone pattern) left, which I will be working on. My current thoughts are:
    1) Noise on the AC Line
    2) A failed or loose filter-cap or ground point
    3) Mis-alignment of the green CRT
    I also noticed that this pattern doen not seem to appear through a pure-red or pure-blue colored object on the screen, which makes me believe that the problem may be tied to the green alignment.
  • 41 Answers
Well, first of all, isn't there a warranty on the repair?
It still could be a bad solder connection somewhere but I have seen what is called a G2 / Focus block go bad causing your symptoms.
Working around those tubes is not recommended unless you know what you're doing. You can really mess up the picture or worse, break a tube.
Posted on May 18, 2009
  • jongar Jun 22, 2009
    You might try taking a pencil and tap the green CRT on the neck above the circuit board using the eraser end. If tapping the board seems to be more sensitive, remove any silicon glue that is holding the circuit board to the CRT and gently remove the circuit board. Check the solder connections. If it is more sensitive on the neck, you may have a CRT going bad. Usually it will get bright green instead of loosing the green all together because of internal shorting of the elements inside the CRT.
    Also, you might check for wet / oily looking spots on the CRT circuit board. If the CRT is leaking coolant, that coolant can cause all kind of strange problems.
  • jongar Jun 25, 2009
    Generally, you can pull the board straight off. Sometimes they use a plastic clamp to help hold it on or silicon doped on the socket. Once those are loosened or removed, gently rock the board back and forth while pulling it off the CRT.
    If you can't find anything amiss and you're bold, you might do a board swap with one of the other CRTs and see if the symptom moves with the board. - Jongar
I have faint wavey lines just watching tv itsself but not when i switch modes to xbox or any other type device what to do?
Check all the coax cable fittings by moving each with set on---you are looking for a loose shield connection (outer one to connections) that can with ease cause this problem.
Nov 02, 2012 | Samsung HCN653W 65" Rear Projection...
My flat screen samsung is green
HI, Green screens are almost always caused by no signal-so check the input connections: rca cable, screw on coax connector, make sure channel is right 3 or 4 for a vcr type connection, sometimes channel 60 for some types of satellites-new rca cable for other connection-can determine if the cables are good by connecting to known working equipment , and make sure the plugs on back of television aren't loose-they've been known to come loose inside from the circuit boards before. Hope this has been of use, good luck Prodzilla
Mar 31, 2011 | Samsung Televison & Video
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
The TV turns on and off after a few seconds and repeats itself.
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
Reverse fisheye!!
you are going to need to replace the convergence board assembly. It is available at http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP95%2D00142P&search%5Fmodel=HCN653W. Also get the service manual, as you will need to do some touchup convergence and reset the perfect focus setup again If you have the technical ability. If you do, great! If you do not, these service menu alighnments can mess up your set, so take no shortcuts. Good Luck
Mar 29, 2007 | Samsung HCN653W 65" Rear Projection...
Bad signal board or something else?
You weren't very specific about your problem, but assuming you've tried different inputs and tried messing with the convergence setting, it may indeed be the signal board, and you may need to have it replaced. BTW these sets also have an issue with the dynamic focus circuit and with crt fluid leakage. Make sure that you do not have a fluid on one of the crt boards. And as always with repairmen, a second opinion couldn't hurt.
Apr 04, 2006 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
485 people viewed this question
Jerry Greenberg
Jerry Greenberg
