Question about Sunbeam Vacuums
My sunbeam water cooler model #YLR2-5-67H3 was bought off original owner and when I plugged in it appears ti not cool. I don't have to owner manual so I can't troubleshoot issue. What can I try?
5 Suggested Answers
  • 11800 Answers
SOURCE: My sunbeam water cooler model
One of the rubber connecting hoses inside it has dried and aged so the pressure of the water from the bottle made it burst.
You will need to open it, find the defective hose and replace it - a 2 hour relatively easy job. The hardest part will be in taking the casing apart - lots of hidden screws.
Posted on Jun 03, 2011
Strattrpt
  • 159 Answers
SOURCE: Hi, I have a older
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Posted on Jun 07, 2011
dttech
  • 4803 Answers
SOURCE: whirlpool drinking water cooler 79R1.Leaking.
You may have to contact the manufacturer directly. Whirlpool never made any water coolers. Whirlpool water coolers were, at least at one time, manufactured under license by a company called Kemflow International LLC. This is a company based in Taiwan. Here is some contact information for the company:
The Whirlpool web site only redirects you to a web site for Kemflow which is pretty useless. It does not even contain contact information on the "Contact Us" page. After some research, I found the following company information:
No. 3 Huan East Street
Da-Zhou
Taiwan Pingtung Export Processing Zone
Pingtung, 900
Taiwan
Founded in 1981
Phone:
886 8 752 4736
Fax:
886 8 753 1524
www.kemflo.net
Posted on Jun 10, 2011
ynogami21
  • 670 Answers
SOURCE: Plugged in my water cooler
hi there,
Possible reasons why it smoked are:
1. The water cooler received too much electricity than what it could handle. example it received 230V instead of 110V.
2. It got wet inside while plugged in and caused a caused a short circuit on the pc board.
Eitherway, to get it fixed.
1. The system needs to be opened so you can check the fuses, capacitors, IC's and make sure that the pc-board does not have a burn mark or any damage.
2. Check if there are swollen capacitors, burned resistors or loose IC's on the board. Check for any open wires as well.
3. Test the capacitors, the IC's and the resistors for continuity in electricity using a power tester.
4. If no continuity is detected on some of the capacitors and IC's then the pc board would have to repalced.
Otherwise you can have a local electrician visit your place so they can do all of this for you.
Hope this helps!
Posted on Jun 12, 2011
I NEED A MANUAL FOR SUNBEAM GCSBRS 101-000 CONVERTIBLE STEAM IRON
Hi there.
You can download Owner's Manual at http://www.sunbeam.com
Regards.
Jul 14, 2011 | Vacuums
Just bought sunbeam 4835 without manual. it seems that the bread dough kneader is not working but the baking portion is. i don't know if it is just me not knowing how to use it yet or if it is...
Had the same problem with mine...turns out a belt in the machinery portion of the bottom had dry-rotted. Got a replacement for $12 from the local sew n vac store. Works now! Good as new,?
Jul 04, 2011 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Jun 07, 2011 | Vacuums
How do I find the model number on my sunbeam mixer? I need new mixing blades
Some Sunbeam Mixers don't have a model number stamped on them. However, the service number located on the mixer functions basically as a model number when it comes to replacing parts. Hope this helps.
May 06, 2011 | Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
Do you have a manual for a Sunbeam Steam Iron Model 48Z6 - E91117
Sadly, the manual referenced above by link appears to be no longer available. I'll keep looking. Thanks
Sep 17, 2010 | Vacuums
Have lost manual for my sunbeam dehydrator model AR72716 07-03 cannot locate one any where
Sunbeam only have 2 listed:
  • DT100E Healthy Food Dehydrator link to manual: http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11092
  • DT5600 Food dehydrator link to manual : http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11096
Does your dryer go by another name such as Excalibur?
Sep 06, 2010 | Sunbeam Vacuums
Vacuums Logo
277 people viewed this question
Top Sunbeam Vacuums Experts
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
