Question about Exercise & Fitness
ProForm XT90 belt making a lot of noise rubbing at top of incline I recentered to no avail by tightening with hex key What next
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
I would recommend you get someone there to check it out...hard to diagnose noise problems like this.
Posted on Jan 04, 2014
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
Robert Braun
  • 77 Answers
SOURCE: The belt on my proform
Is it rubbing off the sides of the belt? If so, adjust the lateral movement of the belt with the hex bolts at the base of the treadmill. If not, you may need a new belt. See Treadmill Parts
Posted on May 03, 2011
ercupa190
  • 12223 Answers
SOURCE: My proform crosswalk treadmill makes
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
Of course after you did step and the problem persist, you must test the main motor complete, mechanical and electrical trouble.
sincerely.
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Posted on Jun 28, 2012
The belt on my proform 680LT has an excessive amount of rubber powder rubbing/shedding off. It makes a mess.
May 03, 2011 | Proform 680 LT Treadmill
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
Belt is skipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 13, 2010 | Proform 325 Treadmill Walking Belt
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
The belt keeps going to one side+ rubbing,, is there anyone that
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes.
May 14, 2010 | Proform 6.5q Treadmill Walking Belt
Belt problem
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 14, 2010 | Proform Sport 1000 Folding Treadmill...
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
How do you adjust the belt on a PROFORM,( Model #
Unplug unit then, using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 21, 2010 | Exercise & Fitness
Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Jun 11, 2009 | Proform 575 Crosstrainer Treadmill
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
