The yamaha rxv 1600 manual does not say if i can run 4 ohm or not does anyone know
The manual says...
"If you are to use 6 ohm speakers, be sure to set the "SP IMP" to "6 ohm Min" before using this unit (see page 30). 4 ohm speakers can be used as the front speakers (see page 118)." ... which basically says the same thing in a table.
Set it for 6 ohms and try ity out. If it exhibits any problems like the amp cutting off you might want to lower the volume or analyze it to see if the 4 ohm guys are the problem.
BTW: That spec is just a nominal value. At various frequencies every speaker's impedance changes. The proof is in the pudding. The Yami won't self destruct unless you crank it to the stops and ignore the audible warnings of stress.
