Question about Sharp Video Cameras
VL-E40 Tape wont eject due to entering wrong
I put the tape in wrong and it won't eject, a light just keeps flashing even when the cameras turned off
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
Posted on Sep 15, 2006
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
SOURCE: Tape Ejection Problem
I have both the willful zoom and the unwilling cassette problems. In the past I have briefly fixed the zoom by opening the door and gently probing the cable to the zoom button. This only worked for a couple of weeks then reverted to same crazed performance. Then last month the "remove the cassette" madness started (bear in mind, I have only recorded perhaps 15 cassettes on this damn thing). Nothing worked. Until tonight when I simply lightly smacked the unit down flat on the manual resting on my desktop. Did this a few times and BOTH the zoom and cassette door started responding properly. I'll see how long this lasts, but it beats buying a new one or dealing with Canon. Never again.
Posted on Mar 09, 2008
SOURCE: can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Posted on Jan 23, 2009
SOURCE: c:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Posted on Jul 16, 2009
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Eject a tape from my Sharp View Cam
Try removing the battery and reinstall it if you haven't all ready tried this
Sep 11, 2008 | Sharp Viewcam VL-A10U Camcorder
My sharp hi8 camcorder will not produce a picture unless it is in the review mode. What can I do?
The loading mechanism is not completing its cycle. That will cause the tape to be ejected as a safety feature so no damage occurs to the tape. This unit will require a "rebuild" to retime the loading mechanism.
Dan
Apr 19, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp Hi8 Video Camera VL H410
This camera needs to have the battery recharged in order to remove the tape.
Apr 14, 2008 | Sharp VL-AH131 Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
1. Turn off power
5. Eject battery
7. Power on
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Oct 31, 2007 | Video Cameras
Camcorder
keep your camera 'ON'for more than 1hr.& cover it with black cloth & keep it in the dry room. regards; shailesh
Sep 02, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Video Cameras Logo
46 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
