Question about Dyson DC40 Multi floor Upright Vacuum Cleaner
Instruction manuals Suction problems
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
SPOT BOT NO SUCTION
Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
I have Electrolux Versatility and have little suction power in the hose part,
Unplug the machine..now if you remove the attachment hose at the body of the vac and feel inside (to the right about an inch) their is a "suction cover" that rotates when the wand is removed (aka using atachments). The cover in your machine is NOT rotating correctly, so it does not get full suction. If you do get some suction from the hose then their is at least a 'small opening' because it has partially rotated. I was able to fix this problem by taking a large screwdriver (1.5 feet long, thick as a pen), inserting it into the small opening (on the suction cover, inside to the right at the top) and forcing the cover down all the way by lifting the screw driver up against the top of the body opening. Seems to have corrected the problem, but may reoccur. If you have NO suction at all then it has failed to rotate whatsoever, and Im not sure how to correct it.
picture of the suction cover part:
http://evacuumstore.com/p-3604-electrolux-versatility-el8502ab-cover-suction.aspx
Nice of that sales lady to provide zero help...
-Steve
May 05, 2011 | Electrolux EL8502 Versatility Bagless...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 | Vacuums
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Poor suction on carpet
Did you check to see if brush is spinning ,
is belt broken? It could be something stuck
in the mechanism in the impeller, shute,etc
Nov 16, 2007 | Vacuums
Dyson DC40 Multi floor Upright Vacuum Cleaner Logo
80 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
