Question about Garden
I am not getting fuel to the carb. I have taken bolt out of bottom of bowl and there is no fuel coming out. I am getting gas at the end of gas line that is hooked to carb. Any advice?
  • mc_magic_mik May 20, 2009
    Yes that was the problem, needle valve was lodged causing the float to be stuck.
    Thank You for your help in this manner.
    Sniper:
  • 57 Answers
Sounds like needle is stuck. Remove the bowl and see if float is hanging down or staying level. Needle is at top of float. There is a pin holding float to carburetor. Remove the float before trying to dislodge the needle.
Posted on May 19, 2009
Ran it out off gas, refilled it now runs rough
very likely that there was some trash in the bottom of your fuel tank and as it pulled the last bit of gas through it could have clogged the fuel filter, of the carburetor. Without knowing the make and model its possible there is no fuel filter some push mowers have a straight fuel line to the carb. If that is the case, on the bottom of the carb there is a bowl most mowers it has a bolt in the bottom middle of the bowl I would remove the bolt and drop the bowl, clean with a wire brush and carb cleaner and reinstall the bowl. I believe that will most likely solve your problem. If it doesn't or you have any questions please leave a comment I would like to help you resolve your problem!
Oct 01, 2015 | Garden
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Wont firi over been sitting for a while
The following applies to pretty much any carbureted engine.
You need three things for an internal combustion engine: Fuel, Spark, and Air.
The first place I'd start is with the spark plug.
Remove the plug. With the plug wire attached to the plug, ground the electrode (threaded part) against the metal frame and crank the engine again. Check to see if there's a spark between the electrodes. If there is, then you've established spark - for that cylinder and only that cylinder. If you have spark in all cylinders, next thing I'd check is fuel.
I would start at the fuel inlet of the carb. Pull off the fuel line and make sure fuel can get there from the tank. If not, you have a plugged filter or debris in the tank that's preventing the fuel from reaching the carb. Clear the obstruction and try starting.
Still won't start? There is the possibility that gas in the carb has dried out. That can plug ports, keep the float from working, etc. Best fix is a carb cleanout.
On some bikes, you can check to see if the float is working. There is sometimes a drain valve in the sediment bowl (on the bottom of the carb). Open the drain and see if gas comes out. If it doesn't then there is no gas in the carb. If no gas comes out, then it's likely that your float is stuck.
If you don't have a drain valve, on some carbs, there is a "nut" on the bottom of the sediment bolt. It's actually a bolt that holds the sediment bowl to the carb. Loosen the bolt until your bowl is free to move. If no gas comes out between the bowl and the carb, your float is stuck. If it does come out, then it could be the needle that meters gas to your engine. Work the throttle a few times and then try again. With the gas in the bowl, working the throttle moves the needle in and out and can clear out enough "varnish" to let gas get into the cylinder.
Again, try starting it. Still no joy, pull the plug and see if it's wet. If it's wet, then it has been getting gas - too much, in fact, but that's because it hasn't been firing. You're back to two issues:
Either the needle isn't closing and too much gas is getting into the cylinder or you don't have spark. If it's the first, then you need to pull the carb for that cylinder, clean it out and re-install. If it's the second, you have an intermittent wiring problem which is going to be a lot of fun to find.
Dec 27, 2013 | 2008 kawasaki Vulcan 900 Classic
How to drain fuel out of the carburator chamber?
Honda carbs have not one but two bolts in the bottom of the carb bowl.
The bolt that comes out at a 45 degree angle is the drain bolt. The other bolt that points straight down holds the bowl on the carb.
Be sure to have a container under the drain bolt and collect all the fuel that comes out. You can use it in other equipment or put it in your car if it runs on regular gas.
The drain bolt can be removed with either a phillips head screwdriver or a 10 mm socket.
I hope this helps!
Nov 23, 2011 | Honda Garden
My 2005 yamaha TTR 125 will not let gas flow into the carb bowl, you can pour gas into it and it starts right up, thanks!
Your float in the bottom of the carb is likely stuck in the up position. The float attaches to a valve that shuts off fuel flow when level is just right. Can you see the little screw at the bottom of the bowl? Do you see the little overflow hose below that? Get a plastic soda bottle, put the outlet of the tiny hose into it. unscrew that little screw a few turns. Do you see fuel coming out? No? then take the back end of a screw driver and tap the bowl of your carb sharply 5 or 6 times. (Make sure the fuel pet **** under the tank is turned on. If you do not see fuel going into your bottle in a minute, shut off fuel at the tank. Screw the bowl drain back in. Remove the larger incoming fuel line that goes from tank to carb and put it into the bottle. Now you will open the petcock a little bit slowly. If you never see fuel come out of the tank, thru that hose, then your screens on the petcock may be clogged. Shut off fuel , Remove the cap on your fuel tank. blow into the line while slowly opening the petcock valve. Hear air bubbling in the tank yet? If you do, shut off valve, remove air pressure from line, point it back into the bottle and reopen the valve. If none of this works, then you need a new petcock valve.
Nov 29, 2010 | 2004 Yamaha TT-R 125 L
My Ariens lawn mower dose not get gas to the Carb float is OK gas line OK.When I push the primer button No gas. Spayed Carb cleaner in carb No change. What can I do next?
You have gas in the float bowl but nothing coming out when you prime correct?
You should remove the bowl jet *(should actually be the bolt that holds on the bowl) and wire brush it clean and then run a fine piece of wire strand through the jets. One of those openings is very tiny.
It is located at the top of the threads and you will need a tiny piece of wire strand to clear this. When you have cleared this and the two bigger openings at the bottom of the bolt put it back in and see if she primes. The primer just puts a raises the air pressure inside the bowl so fuel flows up the main jet. So a blocked main jet will prevent priming and running at anything above idle speed.
Good luck and be careful!
Jul 23, 2010 | Garden
Briggs and stratton 675 seems to not pull fuel into the carb
Start by disconnecting the fuel line at the carb. Blow back to the tank to make sure the line is clear. If not that remove the bowl to see if gas is actually geting there. If it isnt, remove the carb and check the float and needle. If there is fuel coming in, clean out the main jet. It is probably in the bolt you removed to get the bowl off. Good luck...Lee
Sep 03, 2009 | Garden
Craftsman mower will not start without starting fluid
Sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure your float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish by reattaching the air filter support bracket making sure the gasket between the carb and the bracket isn't damaged. Also, never use last year gas, alway buy freah every year.
Jun 07, 2009 | Craftsman Garden
I am getting fuel leaking from the bottom of the carb and I have adjusted the screws on the bottom of the carb but it is still leaking...it is a 1997 flstf fatboy
Carburetors have a Float Bowl on the bottom. This float bowl has a small amount of fuel, that the carburetor uses. (The float bowl's amount of fuel, is replenished from the gas tank. The fuel is gravity fed from the gas tank, through the Fuel Line)
The float bowl has a Float Needle inside. The float needle is attached to the Float. The Float resembles a thick doughnut. On one end of this doughnut, is a flat piece of metal shaped like a U on the end. Looking at this -> U shape, there are two holes at the top. There is a metal pin that goes through these holes, and the pin is attached on it's end's, by the main body of the carburetor.
The flat metal U shape, and the metal pin, works together to form a type of hinge, allowing the float to pivot on it.
Where the U shaped hinge is attached, the float needle, clips to it.
The float needle has a tapered neoprene tip, and sits in a Float Needle Seat. This seat is a barrel shaped piece of brass, and has a tapered hole at the bottom. Fuel comes up through this seat, and the float needle regulates how much fuel can come in.
As the float drops down, it draws the float needle out of the float needle seat, and fuel comes in. As the float bowl fills with fuel, the float rises, and pushes the float back up, also pushing the float needle back into the float needle seat, cutting off the flow of fuel.
There is a specified height of the float, in relation to where the float sits in the float bowl. If the float sits too high, the float bowl fills up with fuel, and overflows. This overflow goes through an Overflow Tube, on the carburetor.
(If the float sits too low, the engine starves for gas)
A LOT of times, crud builds up in the gas tank, makes it's way through the fuel line, and gets into the float bowl. It can get in-between the float needle, and the float seat, thereby flooding the carburetor out, and fuel comes out of the overflow tube.
The float bowl is also attached to the carburetor with a brass main jet nut. At the bottom of the float bowl, this will look like a brass head of a bolt. Under the brass head is a small O-ring. This can leak. First step is too insure this is tight. (Do Not Over tighten! This is part of the main jet, and is expensive! It's Brass)
Where the outer part of the float bowl itself, attaches to the carburetor, there is another O-ring.
A large one. This O-ring, like the main jet O-ring, can deteriorate over time. Additives that gasoline has in it, heat from the engine, and heat from the sun does this. Plus just age. Neoprene breaks down after time.
It could also be that the neoprene tip of the float needle has broken down.
You indicated you adjusted screws on the bottom.
These are the Main Jet, and Idle Jet -> Air Mixture screws. All they adjust is how much air goes through these jets.
The amount of fuel going through, is predetermined by specific passageways, that are drilled through the main body of the carburetor.
This only comes into play when the engine is running. With the engine off, and fuel leaking out, you have crud under the float needle, or one or more of those O-rings has deteriorated.
May 12, 2009 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
