Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
Oven Will Not Start
I have a F2E0 error when trying to start my oven. This is our second home and has not been used in 2 months. This did not overheat. I tested the temperature probe and it tested ok. Any suggestions?
    Habit-Forming:
  • 188 Answers
The whirlpool code is that a key button is shorted/stuck. Say's to replace keypad.
Posted on Dec 29, 2013
4 Suggested Answers
SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Posted on Aug 25, 2007
Amigaman
  • 248 Answers
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
Posted on Nov 24, 2007
blueextc3221
  • 15935 Answers
SOURCE: after a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Model DED0530 wall oven. Tries to start but then why does it indicate 'cooling error lower one'?
[PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m1300016_f20366.pdf
Viking Rangecontact our consumer support center at 1-888-VIKING1. We appreciate your choosing a... Error Handling .... *Note: Professional Series Premiere model control panel and features are shown. Oven ... upper or lower oven, and then set the desired temperature. .... cooled, remove any ash from oven surfaces with a damp.
Nov 06, 2015 | Ovens
When trying to start oven for baking. I set the temp & press start. It shows the selected temperature, then, after about 10 seconds shows 100 degrees. Nothing happens after that. Oven does not ignite....
well, at least your door hinges are still working. Let me guess, this is less than 6 months old. Every review of these ovens shows the door function breaking. I wish I had better news...and good luck!
Jan 01, 2011 | GE 24" Built-In Single Gas Wall Oven
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Getting an error code on the display F2E0 (stuck key). When I was wiping off the display. Is there a way to reset this?
Sometimes you can get lucky by pressing all keys at random several times each. If that does not work you will have to replace the keypad.
Oct 09, 2009 | KitchenAid KEBC101 Electric Single Oven
Jenn-air ove3n flashing a error FR
hi friend,
error:FR
condition:second oven error sensed
resolution:1.check oven temperature sensor and hardness[or]
2.replace second board
hope this helps u
thank u for using fixya
please rate me....................
regards
sivaranjini
Sep 14, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Nov 27, 2008 | Ovens
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Apr 19, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
138 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
