Question about Ski-Doo 2006 GTX Sport 600 H.O. SDI
Front remove seat
I want to take the seat off
    Top Expert:
  • Ski-Doo Master
  • 2,044 Answers
You must drop the Track and suspension to gain access to the Seat from inside the Tunnel
Posted on Feb 12, 2014
Remove front seat from 2005 ford five hundred
Move the seat all the way forward and remove the two bolts going into the cross bar in the back. Move the seat all the way back and remove the plastic covers where the front feet of the seat meet the floor. Remove the two bolts going into the floor. Lean the seat back and disconnect the electrical connectors.Lean the seat sideways so that the outside part is facing up and remove the nut holding the seatbelt to the seat and take off the seatbelt. The seat is now free to be removed from the car.
Nov 28, 2012 | Ford Five Hundred Cars & Trucks
How to remove front seat from 2006 Buick LaCrosse
Front Seat Replacement - Bucket
Removal Procedure
Caution: Refer to
SIR Caution in the Preface section.
Important: The front seat is equipped with a seat belt pretensioner. Disable the pretensioner before you perform any work on the seat.
  1. Disable the SIR system. Refer to SIR Disabling and Enabling and to SIR Disabling and Enabling .
  2. Remove the front seat head restraint. Refer to Front Seat Head Restraint Replacement .
  3. Position the front seat to the full forward and the full-up position.
  4. Remove the bolts from the rear of the seat adjuster.
Sep 21, 2012 | 2006 Buick LaCrosse
How remove front seats from 02 monte carlo ss ?
Remove the plastic trim over the front and rear seat rails and you will see two bolts in the front and two in the rear, reach under the seat, disconnect the wiring to the seat and then remove front and rear bolts and careful pull seat out through the door opening, it is a tight fit don't damage anything, take your time.
Aug 29, 2012 | Cars & Trucks
Front seat removal pt cruiser
If you move the seats all the way back you should be able to get at the front two bolts on each seat. If you move the seats all the way forward you should be able to get at the rear two bolts on each seat. Once the bolts are removed unplug all the harness under the seats and remove the seats from the vehicle.
Mar 09, 2012 | 2002 Chrysler PT Cruiser
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
How do i take out a 2002 impala front seat in order to replace the power seat motor?
the front seat in the impala does not have front bolts...there are 2 bolts in the back..remove then pull back on the seat and lift out !
Jun 04, 2010 | 2002 Chevrolet Impala
Remove front seat
SECTION 501-10: Seating 1998 Escort/Tracer Workshop Manual REMOVAL AND INSTALLATION Seat —Front Removal
NOTE: Driver side seat shown, passenger side seat similar.
  1. Slide the seat to its rearward position.
  1. Remove the front seat track to floor front bolts.
  1. Slide the seat to the forward position.
  1. Remove the front seat track to floor rear bolts.
  1. Disconnect the safety belt warning indicator switch electrical connector.
  1. Remove the front seat.
Dec 06, 2009 | 1998 Ford Escort
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
Installation
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
Ski-Doo 2006 GTX Sport 600 H.O. SDI Logo
474 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
