Question about Zenith DVC2550 Multi-disc DVD Player
Disc Tray I have DVC2550C and the disc tray won't close! I've checked to see (as much as I could) if there was anything in the way - can't see anything. So if I try to close it either by pressing the Open/Close button or by powering Off - it will close then open again! Any idea what could be causing this problem?
  • tradingco Nov 26, 2008
    My player does the same thing. It will open back up when you go to close it or power off.
    Top Expert:
  • Zenith Master
  • 28,717 Answers
The door switch has been damaged or a belt is slipping or the timing is out because it has been forced by the description of your problem.
Posted on Dec 02, 2017
zeusfaber
  • 247 Answers
SOURCE: DVD tray will not open.
Have a look around the tray and see if you can spot a small hole (about a millimetre or 3/64" in diameter) in the fascia. Very often bang in the middle right below the tray. If you find it, you're in luck. Get a large paper clip and unwind it until you have a long straight piece of stiff wire with a small handle on the end. With the power off, gently push this wire straight into the hole. The secret is to go straight in, perpendicular to the fascia. What you're trying to do is to press on a small pad hidden behind the hole: if you miss this, there's no knowing what you might disturb instead. If you get the wire in the right place, and the whole thing hasn't seized solid, pushing gently on the wire should unlatch the tray - after which you can gently slide it open and get your disc out. A.
Posted on Jun 03, 2007
Paeroa
  • 457 Answers
SOURCE: DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Posted on Sep 13, 2007
eagle338
  • 4889 Answers
SOURCE: Tray will not open when I press button
The tray will have a supporting element which lifts the tray up and ejects the drive..I think probably its worn out..You just need to replace it..it shouldn't cost you much..
Posted on Nov 13, 2007
worldvet
  • 859 Answers
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Regards,
Worldvet
Posted on Jun 15, 2008
SOURCE: Disk tray keeps opening and would not read disk
This thing is a piece of ****
Posted on Jul 22, 2008
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
CD cannot load, will not eject, had to wind down transport manually to get CD out
see this steps and fix it. God bless you
Service a DVD player disc tray:
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 02, 2012 | Televison & Video
Monitor doesnt want to open
SEE THIS CAUSES AND FIX IT. God bless you
Oct 01, 2012 | Dual XDVDN9131 Navigation system with DVD...
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Games wont play
Check if theres anything blocking the disc drive.If that doesn't work each game has a warranty.
Jun 26, 2009 | Microsoft Xbox 360 Console
Xbox 360
THINGS TO TRY loadTOCNode(1, 'whattotry'); 1. If possible, remove any discs that are in the tray. 2. Push the eject button to close the tray. 3. If the tray won't close and seems to be stuck, gently move the tray up, down, and to the side. 4. Check around the disc tray and make sure the faceplate is fitted correctly. If the faceplate isn't fitted correctly, the disc tray may not be able to close. 5. If the tray still does not close, contact Xbox Customer Service.
Jul 30, 2008 | Microsoft Xbox 360 Console
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Zenith DVC2550 Multi-disc DVD Player Logo
43 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
