Question about Eagle TT318E-DV
Electric motor buzzing
Have a TT318E-DV compressor, when I start it all I get is a buzzing from the electric motor. It does not seem to turn or even attempt to turn. Running it on 120Volt, 20 Amp circuit and it blows the circuit breaker within 3 sec.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You need to check for a bad capacitor first which it might not have... then suspect a bad motor.
after research it appears you might have two caps on top of the motor
Posted on Dec 30, 2013
Air compressor won't start
does the motor just buzz when you switch it on? if so renew the start caacitor
Mar 09, 2014 | Mi T M Mi-T-M AC1-PE15-20M Electric...
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Every 2-3 minutes it sounds like something is trying to start and then the starter type switch stops, now freezer is starting to frost. It has been happening for about 3 weeks now but the starting noise...
Compressor problem. There are start components mounted on the side of the compressor, and should be removed and tested. The parts include the start relay, (start/run capacitor if it has one) and the overload switch.
To test these components you must have a working knowledge of electrical an use of a good VOM meter.
If not, remove the parts, and take them to an appliance parts house. They usually are happy to test them for you.
If they test O.K. you have a failed compressor.
P.S. If this machine is under 5 years old, the compressor is under warranty, (some have an extended 10 year warranty). if the warranty is in effect, do nothing. Call the dealer who would handle the warranty. You would have to pay for replacement of the start components, but having it serviced by an authorized warranty station will keep the balance of the compressor warranty in effect. Hope this helps... Jack
Oct 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Older t 30 won't start
I believe your capacitor or capacitors are going out. Or one of the three phases has popped a fuse.
If there is a fuse box for the unit, shut off the breakers on the wall to the unit and do a continuity test across each fuse.
If nothing is found, remove all motor capacitors and bring them into you local electric motor repair shop. Usually they will check capacitors for free.
This should do it.
Mar 31, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Air compressor will not start at all
unplug unit look for a fuse on back of motor - must have built in reaker some where-n these are high rated units - electrical for sure
Oct 05, 2008 | Campbell Hausfeld 28 - Gallon Air...
No cold in fridge or freezer: buzzing compressor
There is no start motor. If the brand of the compressor is a tecumpseh then it is most likely the problem and has a 5 yr warranty from the date of purchase. If it is an Embraco compressor I would try and overload and relay. They are all in one part sometimes called a start device.
Sep 24, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Eagle TT318E-DV Logo
51 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
george parkes
Bill Boyd
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
