Question about Philips 42PFP5332D 42 in. Plasma Television
PHILIPS 42FPF5332D/37 The TV powers up, but have no sound and a black screen. A solid blue light on the front which then blinks 4 slow flashes and then 6 fast flashes. On the back of the TV, board part #PS-425 PHN,LJ44-0011PA the light is flashing 6 times
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
SOURCE: Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Posted on Nov 02, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have a Philips 52PFL7422D/37
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Aug 30, 2011
SOURCE: Philips 42PF7321d/37 Screen Black and no sound. Green LEDS on board below Power Supply one flashes and the other stays on solid. Also noticed 2 capacitors on Power Supply Bulgedtops bulged.
Your problem could very well be related to the defective Caps. Have them replaced with quality caps such as Nichicon or Panasonic.
Posted on May 21, 2012
palaboy
  • 5807 Answers
SOURCE: philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Posted on Sep 10, 2012
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Part # Lj44-00117A
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 42PFP5332D 42 in. Plasma Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
