Question about Gateway FPD1975W 19" LCD Monitor
Monitor is trying to power on but shuts off - Gateway FPD1975W 19" LCD Monitor
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
Monitor turns on for about half a second, then screen shuts off
There is a power supply problem and inverter board issue, cause usually bad capacitors in the above mentioned, sometimes they bulge at the top indicating they are open, repairs can run to the point that it may be cheaper to replace the monitor.
Mar 04, 2011 | Samsung Syncmaster 940BW LCD Monitor
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
Monitor wont power back on, Tried almost everything. Some days it will power up , sometimes is wont. If my timing is perfect and I plug the monitor into power cord at exact time I turn on computer it will...
Hello Adam,
You have a monitor with a power supply that is failing. The most likely cause is capacitors on the power supply board. We have an article posted on our site at: http://www.ccl-la.com/blog/index.php/capacitors/ That explains what they are and what you need to get to repair the board. If you don't want to do the repair yourself then we do offer a repair service, more information on this can be found at:http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please contact us thru our web site.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 14, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Srtyws
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
Mar 11, 2010 | Sony SDM M51 15.1" LCD Monitor
Power supply has shut down, with the power -on LED flashing on and off. It rather looks as if the power supply is trying to start up and then immediately shuts down.
what system is it connected to laptop or desktop? if a laptop try using the Fn+ Monitor buttton ...it may be in a different mode .. if desktop try another monitor if it works then the issue is something else or if it still does not work then it could be a loose video card try reseating the Video card
Oct 06, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Popping sound, black screen
Has it bitten the dust? Probably.
May 18, 2017 | Proview PL926WBi 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
