Question about Exercise & Fitness
Proform 785SS was in flooded basement.
It has dried out but start off aat super high speed. When I adjust to a lower speed it surges and then goes slow and eventually stops. Can it be repaired?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Controller faulty...replace controller....you can get used parts at www.usedtreadmillrepairparts.com
Posted on Jan 04, 2014
2 Suggested Answers
  • 84 Answers
SOURCE: speed will not adjust. will only run at high
if the board got wet most likely its shot its like dropping your cell phone in water it is not going to work rite or not at all
Posted on Mar 10, 2011
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
When I turned ON my proform 550e the speed is super high making imposible to even try to run on it, after pressing the speed down arrow the motor stops completely. I do not have any control on the speed,...
adjust the speed sensor, clean, and tigh the connector very well, see the diagram attached,
2) RUN the software calibration for diagnose, and troubleshooting and fix it.
sincerely .God bless you
Apr 29, 2012 | Exercise & Fitness
When i start my proform 705 trainer the speed goes up and stop , the controller is faulty .What component in the mc-2100lts-30 should i replace to fix it
Dear Sir:
You must adjust , clean, and tigh very well the connector from speed sensor. see the diagram attached.
After that RUN the software calibration.
sincerely. God bless you.
ernesto cuadra
Apr 21, 2012 | Proform Exercise & Fitness
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
Speed will not adjust. will only run at high speed. treadmill was in a basement that flooded. flood was about two weeks ago. allowing treadmill to dry out
Mar 10, 2011 | Proform Exercise & Fitness
I have a proform xp 550e trademill and i changed the motor control board because the motor start running and inmediadlly stops. after i installed the board the motor start running and stop some time after...
To calibrate the speed follow these steps.
Press stop and speed up and place the safety key in its spot.
release the stop and speed up.
Press stop again. The windows on the console (speed & time) will be all zeros.
Press speed up, the time window will increase. The belt should start to move. Increase this number to 85. This is maximum speed. Adjust the potentiometer to the correct maximum speed. The console will beep until the correct speed is adjusted (+ or - .2mph).
If the machine suddenly goes dead when in use, you may have a static electricity problem.
Check that the ground pin is present on the plug and check your outlet for a proper ground connection.
Dec 29, 2010 | Proform Exercise & Fitness
Treadmill speed control does not work - only max.
visit www.iconfitness.com and enter your full model number to print out a speed calibration procedure. Sounds like it needs it. We are a service dealer for them.
Aug 10, 2009 | Proform Crosswalk 3.0 XT Treadmill
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
