Question about Garden
Carburator problem on Bolens 150 weedeater
I have been given a Bolens 150 weedeater that did not run. I replaced fuel lines & sparkplug. It started but did not run for more than a few seconds. I took off the carb and disassembled it and cleaned everything with carb cleaner. I have reassembled. Now when I try to prime the engine, there is no draw from the fuel tank side. I have the lines correct (fuel intake to short stem on bulb) but there is absolutely no suction on the fuel side. The bulb works because I disconnected the fuel side line, stuck the end in some fuel and the bulb draws the fuel out easily and pumps it out the return line.
  • 97 Answers
SOURCE: fuel line routing help.
You should have one line (with filter) going to the carb inlet & one line going to the bulb then back to the tank.
Posted on Mar 17, 2009
  • 97 Answers
SOURCE: Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Posted on Mar 21, 2009
  • 9 Answers
SOURCE: weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Posted on Jun 18, 2009
  • 202 Answers
SOURCE: lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Posted on Jul 08, 2009
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Tries to start but won't? Replaced plug and fuel lines.
hi
check the compression,ignition sistem ,carburator and fuel lines (is there any spark,is the spark bright blue,does the fuel reaches the sparkplug.try put some small amount of gas inside the cilinder to seee if the engine starts and run.
regards savumihai71
Oct 29, 2010 | Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
Weedeater will not start
For a weedeater that only runs when you prime or inject fuel manually the easiest thing to try first is replacement of the fuel filter. I have had this happen several times over the years and other than a broken or cracked fuel line the filter usually is the problem. If this does not work, then work on the carburator may be needed, but the filter is an easy common problem.
Sep 01, 2009 | Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
New carburator doesn't passed fuel
Are you sure that that the replacement is the correct one. Also, why did you have to replace the carburetor . Did you verify that the carburetor was the problem? Did the weedeater run by priming? Did you check the pump and lines? If these methods were tried and did not reveal the problem, then I suggest that you get professional help.
Oct 23, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
