Candy ctg 1456
The machine does not take in soap from the soap dispenser. I have totally cleaned the dispenser.
  • Erling Christensen
    Erling Christensen Dec 30, 2013
    When we are using soap powder (not floating) soap it is not getting in the machine. We are using two of the left chamber in the soap dispenser under the top door. Is it perhaps better to use floating soap. It seems that powder is being hard and left in the
    soapdispenser
  • 1294 Answers
SOURCE: soap dispenser
Refer to the manual. You can use a tooth brush to clean out.......
Posted on Dec 28, 2007
mikedurland
  • 481 Answers
SOURCE: SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Posted on Aug 08, 2008
  • 958 Answers
SOURCE: Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 353 Answers
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Posted on Dec 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: he4t dispenser problem soap
Remove the soap tray and clean the orifice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
How to clean soap dispensers on hotpoint washing machine
use very warm water and bleach then put mech on final rinces no clothes and let it go through cycle
Mar 02, 2015 | Hotpoint Washing Machines
My candy cna 145 will not let water into drum. all just floods out of soap dispenser
It sounds as though there is a soap powder blockage in the dispenser or the dispenser hose in to the drum.
Try pushing into the hose with something to clear the blockage.
Please rate my solution.
Jan 23, 2010 | Candy Washing Machines
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Mar 08, 2009 | Whirlpool AWM8143 Front Load Washer
Candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Jan 19, 2009 | Candy CNW136 Front Load Washer/Dryer
He4t dispenser problem soap
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
SOAP DISPENSING
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
