Question about Garden
Need digram to install fuel lines
Fuel lines dry rotted and fell off i just need to know where they go is there a diagram available
  • Anonymous May 23, 2009
    i have a craftsman lawn trimmer model # 358798442 the fuel lines have dry rotted and i need a schematic to install new ones.
  • 41 Answers
First, you sould have one with a filter in the tank going to carb. Next run one from tank to primer bulb and from one from primer bulb to carb.
Posted on May 18, 2009
Need fuel line digram for 91 grand marquie
Really?
Go on Google, and type "1991 Mercury Grand Marquis Fuel System Diagram." Dozens of them some up. (Helps if you know how to spell the model name of your car. When in doubt, it says on the car, in several places, and in big letters.)
Jul 21, 2014 | 1991 Mercury Grand Marquis
Need a digham for poulan chain saw fuel lines the old ones dry rotted and i dont know how to install the new ones
James I have the same problem. Can you help with a picture or instructions on how to fix please
www.oneway@bellsouth.net
Thanks, .
Oct 03, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Trying to start weedeater. Starts but wont continue running. we just replaced the fuelines need to know how far down the blue line should be in the tank.the olds ones were dry rotted so we re not sure if...
There should have been a fuel filter attached to the fuel line. So when installing quite tricky, put line in tank, place filter on end of line while in the tank, let filter lay flat on bottom of the tank.
In those carbaretors there are gaskets and a diaphram. After awile they ware out and the diaphram which is rubber gets hard, so it will no longer pump fuel. You can buy everything for the cab in a kit. I hope this helps you.
Jul 14, 2011 | Garden
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration...
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Nov 10, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
The fuel line is rotted and the fuel filter fell off (along with parts of the rotted fuel line). How is this best repaired?
Take a piece of the old hose to a parts store. Buy new line and cut to the same length as the old line and replace it.
Sep 13, 2009 | Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Which fuel lines conncets to the carburetor?
Well I finally got my saw running - it occured to me that my older chainsaw never had a primer bulb - so I bypassed it and...pull started it with the choke on till it chugged - then turned the choke off and held the gas full on - pulled the starter cord and was cutting trees - LOL
I did speak with a small engine guy - he explained that the primer is to pressurize the gas tank - so your return line from the carb goes to the suction side of the primer bulb - output to the tank - and pickup line with filter goes to the intake of the carb - FYI - hope it helps ya!!!!!!!!!!
Mar 18, 2009 | Garden
Chainsaw won't stay running
try fuel first drain fuel out replace . add small amount of carb cleaner , i like sea foam myself , available @ advance auto or like store then retry might have to restart several time to get into system . if no good then possible diaphragm in carb . but worth a shot before tear down
Dec 28, 2008 | Garden
Garden Logo
433 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
