Question about One For All 106 Penn State Remote Control
Code tv bush id bbe digital - One For All 106 Penn State Remote Control
Srs bbe
SRS means SurRound Sound which is simulated to what is called BBE high definition sound enhancement i believe this was got from a car radio device from the word PREMIO it was a toyota premio
its used in tv sets and hi fi audio and car audio systems and NO its not a tv but a monitor, u will need a dvd car audio thats compatible and given they r custom made for premio u will need the exact march to use it.
Jul 14, 2013 | Televison & Video
I can find no replacement remote
The remote you have now has no setup codes for Bush TV. RXA RCR 311W-Model remote have setup code for Bush TV. the code is [1056]
With your present remote control, do a code search method, If there is a code pre-setted for Bush, you will get it.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out
If code search method do not help you, please understand that, the remote control you have now can't be setup with your TV.
Jul 03, 2012 | RCA Universal Remote Control
How to reset password or hard reset crossover ds48
Just spoke with BBE and they said the only way around this is to send them the unit and they will replace it with an unlocked unit. There is no charge, just shipping it to them in southern California.
Jun 27, 2011 | BBE DS 26 Digital Crossover and Speaker...
I'm looking to get help with the equalizer settings on my Philips 47 in LCD TV. It just doesn't sound very good....Need help
hello,
Philips 47PFL7403D have Equalizer: 5-bands
Output power (RMS): 30W
Sound Enhancement: Incredible Surround
Sound System: Dolby Digital (AC-3), BBE.
Mar 27, 2011 | Philips 47PFL7403D 47 in. LCD TV
Fuse amp size for 32" bush iD
If you mean the mains input fuse then usually 3.15A Fast Blow.
Other fuses vary.
Dec 24, 2010 | Bush 5693D 24" TV
I have 37" bush ID the picture is dead, black
THERE ARE BULGED CAPACITERS IN YOUR POWER SUPPLY REPLACE THEM
Nov 17, 2010 | Televison & Video
We can't find the cable connection to a Protron tv.
can you tell me the model of your protron lcd?
Jan 06, 2010 | Televison & Video
Power supply fault?
Check all electrolitic capacitors at power supply area : better replace them.
Apr 15, 2008 | Bush 2871NTX 28" TV
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
One For All 106 Penn State Remote Control Logo
15 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
